Old 06-28-2018, 09:21 PM   #1
ZEKE68
ZEKE68's Avatar
Running wires down A pillar?
Anyone have any advise about running wires down the left A pillar from the inner roof to under the dash. I don't see any obvious holes or routes.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 06-28-2018, 09:42 PM   #2
Ramjet51
Re: Running wires down A pillar?
I did it for my mic on the radio, PITA, but it is possible, since my cab was originally a C30, the mirror mount was the plain Jane Steel, when I switched to the nice early model Crome base it opened up an extra hole for the mic cable......and I installed an extra pull string just in case...oh...I may need to mention that I used an iPhone bore scope to accomplish the task...
You'll never know unless you try
Ramjet51 is offline   Reply With Quote
Old 06-28-2018, 10:22 PM   #3
Acorn
If you have some good Google/search Kung fu you can look up a video that member Txfirefighter (I think) posted. He ties a piece of string to the wire he wants to run, then he uses an air hose to blow the string UP the piller to the sun visor hole then just pulls the wire. Simple and effective.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 06-28-2018, 10:42 PM   #4
B. W.
B. W.'s Avatar
I've used old speedo cables (inner cable) as snakes to install wires in roofs.
B. W. is offline   Reply With Quote
Old 06-28-2018, 10:42 PM   #5
ZEKE68
ZEKE68's Avatar
Can't see any hole under the dash that is in the area of the A pillar. Guess I will splice longer wires and run under the door sills to the rear cab post and up it and across the roof to the mirror area.
Old 06-28-2018, 11:19 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
My FiL did this to run speaker power wires to the cheezoid speakers he put in the headliner. I pulled those wires out. They were laid under the A-pillar cover, not up inside the A-pillar. I'm probably going to get one of those Brothers headliners with the 4 speakers, and put the radio up in that headliner, too. That way, we can put the rear view camera monitor in the radio slot, and let it cover the ash tray as well. My wife quit smoking over 35 years ago when we started having children She smoked maybe a pack a week, so that wasn't a great sacrifice- and if we can't put stuff in the ash tray, what do I care? I'll have a camera that will provide safety for us and other people who are walking by when I back up. Win-win.
~Steven
Simi Valley, CA
Old 06-28-2018, 11:20 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
https://www.youtube.com/watch?v=-53f...ature=youtu.be
LockDoc
Leon
Old 06-28-2018, 11:47 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Holy Smoke, that looks easy! I learned something today. Now, if I can figure out how to not remove the instrument panel, or only move it a little bit..
~Steven
Simi Valley, CA
Old 06-29-2018, 01:33 AM   #9
HO455
HO455's Avatar
I did it on my Burban. I did a search for A pillar rust repair and found some pictures of one dissected then I knew what I was up against. I ran the pull wire down and pulled the wires up from below. Now I realize the headliners are different on a truck than a Burban but the photos from a truck A pillar helped me. The tail light harness runs through the A pillar on a Burban so I had to fight with that too.
Good luck!
RIP Bob Parks.
Old 06-29-2018, 01:38 AM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
That's how they got the roof running lights to work on all 1960--99 trucks even the C50-C80's where done that ways even with the light bar.My 1968 long horn is done that way
stsalvage is offline   Reply With Quote
Old 10-06-2018, 01:26 PM   #11
Castle09
Good luck!
Been searching for two days. I’m going to get into repairing the rusty pillar (upper, under the drip rail) did you see this repair on here or the web? Is this not a common rust spot? I’m guessing not since they don’t make replacement patches.
Castle09 is offline   Reply With Quote
Old 10-06-2018, 01:46 PM   #12
PDXk5
PDXk5's Avatar
Originally Posted by LockDoc View Post
That's a cool trick. Very awesome. I don't have a current need but kinda want to do it just to try it out!
PDXk5 is offline   Reply With Quote
Old 10-06-2018, 01:47 PM   #13
HO455
HO455's Avatar
Here is are some links. I think I found others by searching for "cowl rust".
http://67-72chevytrucks.com/vboard/s...=411447&page=2
http://67-72chevytrucks.com/vboard/s...d.php?t=448133
RIP Bob Parks.
Old 10-06-2018, 03:47 PM   #14
Castle09
Good luck!
Old 10-08-2018, 07:41 PM   #15
Castle09
That’s it. 👍.
Old 10-09-2018, 11:39 AM   #16
ZEKE68
ZEKE68's Avatar
I gave up on running wires down the A pillar. Instead I ran from the center mirror location back between the roof panels to the courtesy light above the rear window, and from there over to the left door. Then up the floor track to the dash. Long way, but it worked.
Old 10-09-2018, 12:26 PM   #17
ZEKE68
ZEKE68's Avatar
