Re: Help a NOOB - A continuing saga
Fuel seeping out isn’t always caused by a leaking needle/seat or a float problem.
A lot of times it’s caused by the person pumping the crap outta the pedal to try to get it to fire. All that pumping sends a big shot of fuel into the inside of the carb. If your choke worked, you likely won’t need to overwork the pedal. Likely your inexperience is causing the seeping. Don’t fret, I mean no harm. Just pointing out one of the ways you’ll see seeping. We’ve all been guilty of the same action. You need to get your choke working. |
Junior Member
![]() Join Date: Jul 2014
Also you're using a divorced choke and it appears in the pix that the rod is not connected to your linkage.
#3 | |
The actual rod feels like it is rubbing the cover when connected, so I thought maybe the friction was preventing the linkage from behaving properly. I think I need to bend it some to try to eliminate the rubbing, but I will reconnect it. |
Were you able to see or tell where the fuel is leaking from?
The fuel leaking out isn’t nessasarily “the problem” if that makes sense. It is a problem but might not be what’s making it run poorly.
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
Who Changed This?
![]() Join Date: Jan 2013
If I was on your side of the continent, I could lend a hand. It just grinds my gears that stuff like this happens and the owner can't get decent help.
#6 | |
Incidentally, I am going to have to get some pics up of the whole truck, because MAN it's almost a clone of the one in your pic. |
Welcome to the greatest web site on the Internet!
Man, I wish I was closer to you. Hate is a strong word, but I HATE when a shop takes advantage of a customer. It's painfully obvious to me that you took your truck to a shop that has "parts hangin monkeys" that rely on the ECM to tell them "what to fix", as opposed to ACTUALLY having the knowledge to DIAGNOSE. |
#9 | |
Active Member
![]() Join Date: Jan 2016
I'm glad there's guys like you out here on this forum. I'm at my whit's end with a rear brake drum job I'm working on on my C20 and would love to have a volunteer to lend me a hand. I'm a rookie at doing brakes on this truck, even though I changed the motor myself. I never in a million years would've thought I'd change the motor but I did with the help of friends and family. It's reassuring to see people like yourself that feel the pain of struggling gear-heads, so thank you for understanding. I'd fly you and your family out to MN for a semi fabulous vacation out here if I had the money. Haha!
#10 | |
I say this link somewhere. You might get lucky and only cost you a beer or three! https://global.nextdoor.com/?country=in |
#11 | |
Active Member
I'll try to observe more closely next time, but I would say it seemed low and near the back of the carb; a little on both sides.
