Old 07-03-2018, 01:18 AM   #8
dsraven
Re: 54 rear suspension - factory strut/coil spring?
also a great time to replace the suspension snubbers if you plan to lower it, your back will thank you later.
if you take the box off for a look-see also check the steel and rubber brake lines, since you will be right there.
