Old 06-22-2018, 11:13 AM   #1
70GMCer
70GMCer's Avatar
AC Orifice Tube
I am starting to get together the parts needed to bring back to life the AC in my 83.
It looks like the system had already been converted to 134 as there are the correct manifold connectors present, but I'm going to replace the orifice tube.
I need to know if the orifice tube for the R134 is the same as R12.
If not, anyone have the part number of the tube I would need?
I'm going to be replacing the dryer, hoses, evap unit & condenser as well as installing a Sanden 508 type compressor.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-22-2018, 11:43 AM   #2
v30crewcab
v30crewcab's Avatar
Re: AC Orifice Tube
it will work with the stock one, but a slightly smaller orifice works better. stock is .072. a 38621 is .067, or a 38635 is .062, which is what I am running in my truck. With the sanden I would run the .062 it will work great.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 06-22-2018, 11:47 AM   #3
70GMCer
70GMCer's Avatar
Re: AC Orifice Tube
Where did you get yours?
Never mind....found it....thanks.....
1997 GMC Sierra Ext
1965 Mustang
Old 06-25-2018, 03:55 PM   #4
Jeepwm69
Re: AC Orifice Tube
You replacing an R4?
Where are you getting your replacement components?
Jeepwm69 is offline   Reply With Quote
Old 06-26-2018, 10:14 AM   #5
70GMCer
70GMCer's Avatar
Re: AC Orifice Tube
Bought all the replacement parts from Rock Auto & eBay
1997 GMC Sierra Ext
1965 Mustang
Old 06-29-2018, 12:16 PM   #6
DieselSJ
Re: AC Orifice Tube
They are color-coded by size. Get the blue one.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 07-06-2018, 12:38 AM   #7
Woodyboat
Woodyboat's Avatar
Re: AC Orifice Tube
You just stated here that you're replacing the DRYER? If your system uses a dryer, I don't believe it will use an orifice tube. Instead, a system with a dryer uses an expansion valve that will be near the evaporator somewhere under the dash...I think.
A system with an accumulator will use an orifice tube. I'm not totally sure that I'm correct on this but I feel pretty certain that I am. One problem is that there is SO much MISinformation out there that it's really difficult to know what you have, how it's supposed to work and so forth. I honestly believe that the industry does NOT want DYI folks like us fooling with their AC systems when so many mechanics have spent thousands of dollars on machinery to reclaim refrigerants and so forth. It's such a huge profit margin for them too.
Here is one very important lesson that I've learned by working with the AC systems on my cars and trucks: DO NOT BUY A REMAN CONPRESSOR! THEY ARE WORTHLESS! Spend a few more dollars and get a brand new compressor. It's not important how I know this.
Dave
Woodyboat is offline   Reply With Quote
Old 07-06-2018, 10:15 AM   #8
SunSoaked
SunSoaked's Avatar
Re: AC Orifice Tube
Originally Posted by Woodyboat View Post
You just stated here that you're replacing the DRYER? If your system uses a dryer, I don't believe it will use an orifice tube. Instead, a system without a dryer uses an expansion valve that will be near the evaporator somewhere under the dash...I think.
I think you're correct. I was wondering about that too. I'm currently swapping in a Vintage Air Surefit system in place of the OEM in my 85. There is NO orifice tube included or mentioned in the kit or instructions. And like you said, there is a " mushroom shaped" copper or brass valve thingy with a copper capillary tube coming out of the EVAP case.
SunSoaked is offline   Reply With Quote
Old 07-06-2018, 10:33 AM   #9
Woodyboat
Woodyboat's Avatar
Re: AC Orifice Tube
Yup, that mushroom shaped copper/brass thingy is the Thermal Expansion Volvo. ...er VALVE. LOL It's often just shortened to TXV. The capillary tube will have a bulb on the end of it that gets fastened up against one of the lines of the evaporator. It's really important that that bulb makes a very good contact with the tube that it is fastened to. I have always used a small hose clamp on it to make sure - which is way better than whatever I've ever seen any factory use. Anyway, it just gets attached to the side of the tube so that it can sense the temperature and adjust the TXV accordingly. So, go get yourself a little hose clamp... unless of course, it's already connected for you.
Dave
Old 07-06-2018, 10:34 AM   #10
70GMCer
70GMCer's Avatar
Re: AC Orifice Tube
Some ac systems had a POA Valve or "Expansion Valve". My 83 has the "Orifice" that goes into the liquid line prior to the "Evaporator" to meter the refrigerant. The "Dryer I refer to is a dryer/accumulator that is attached to the outside of the Evap Box. The Vintage Air systems have "Expansion Valves" in their systems & their dryer/accumulator is attached to the Condenser....
1997 GMC Sierra Ext
1965 Mustang
Old 07-06-2018, 11:08 AM   #11
Woodyboat
Woodyboat's Avatar
Re: AC Orifice Tube
Ok, I just went to the Vintage Air website and had a look. In the photos (at least for the system they show for MY truck - an '86 crew cab) they show the dryer mounted to the condensor. This is definitely then a TXV system and not one with an orifice tube and there is no accumulator. The Thermal Expansion Valve is mounted inside the under dash unit and it's already fitted for you. You won't have to do anything else. Yayyyyy!
By the time a man would go out and buy all the replacement parts to revamp the original factory system, he would only be a few dollars away from Vintage Air's entire kit. I can tell by experience that their prices seem really reasonable - especially if you're upgrading a truck that has never had factory air.
Dave
Old 07-06-2018, 12:12 PM   #12
v30crewcab
v30crewcab's Avatar
Re: AC Orifice Tube
I just spent 75 on custom hoses, 150 on a new compressor, and 35-40 for a accumulator and orifice. not even close to a vintage air system. I have over 1200 in my vintage air system in my 53 belair.
71 longbed 5.3 4l80
Old 07-06-2018, 12:33 PM   #13
SunSoaked
SunSoaked's Avatar
Re: AC Orifice Tube
True, but, keep it a fair compareson. A complete kit is around $1300. The EVAP itself is 750 of that. I swapped everything under the hood intending to keep my factory EVAP and controls. When I got to that point a week ago I had second thoughts when I began trying to hook up 30 year old parts to my new, modern vintage air parts. I decided not to half-ass it so I bought the EVAP kit. Soooo glad I did! Now I have a completely new system from end to end. I must have yanked 100 pounds of vacuum lines, wires, old brittle plastic connectors and spaghetti ducting, cables, etc out of there!
It's now simple, clean, insulated, and hopefully works as good as it looks. In my case, I plan to keep the truck forever and it's supposed to be 115 degrees here today!!! I think the price will be worth it. I
Old 07-06-2018, 01:42 PM   #14
70GMCer
70GMCer's Avatar
Re: AC Orifice Tube
I bought a new Evap, Condenser, Sanden 508 Compressor & compressor brackets, orifice tube, dryer/accumulator and I'm into it for $450.00
I haven't bought the AC lines yet, but I figure about another $100.00
When all done, I'll have a new system for around $550.00
1997 GMC Sierra Ext
1965 Mustang
Old 07-06-2018, 02:33 PM   #15
70GMCer
70GMCer's Avatar
Re: AC Orifice Tube
Rock Auto Four Seasons 54275 Evap $53.79
Four Seasons 33204 Drier/Accumulator $13.75
Spectra 73642 Condenser $72.79
Four Seasons 26739 O-Ring kit $3.83
10% discount $7.21
Shipping $16.98
Amazon Four Seasons 38635 Orifice Tube $5.61 free shipping
Ebay Sanden 508 Compressor $119.00 free shipping
Summit Vintage Air Side-Mount Compressor Brackets 151370-BCA $101.00 freeshipping
total $493.96
1997 GMC Sierra Ext
1965 Mustang
Old 07-06-2018, 02:43 PM   #16
hatzie
Moderator
hatzie's Avatar
Re: AC Orifice Tube
You know these don't have dead insects, mud daubers, and old mineral oil that turned to shellac inside em.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-07-2018, 11:00 PM   #17
SunSoaked
SunSoaked's Avatar
Re: AC Orifice Tube
Ok I got a question. Why don't my V/A kit use any hardlines? It's hoses, 100%. I'm assuming technology has evolved and the hoses don't collapse on the suction side? Or, is it a durability issue on mass produced vehicles?
Old 07-08-2018, 06:36 AM   #18
70GMCer
70GMCer's Avatar
Re: AC Orifice Tube
I think it has a lot to do with production costs.
There are so many different hard lines out there, it would not be cost effective for an aftermarket company to make them.
Even the Vintage Air I installed in my 63 Impala has all rubber lines.
1997 GMC Sierra Ext
1965 Mustang
Old 07-08-2018, 07:17 AM   #19
Woodyboat
Woodyboat's Avatar
Re: AC Orifice Tube
Yes, and if you think about it, hard lines are made for production cars that have their routes already mapped out. All rubber lines can be very flexible making installations in a variety of vehicles possible. Interestingly, the mobility van that I use to carry my parents' wheelchairs has a front and a rear AC. From the compressor back to the rear, all the lines are rubber - no hard lines at all.
Dave
