Old 05-08-2004, 05:44 PM   #1
MACKL
Almost done!
MACKL's Avatar
Dash swap
My 70 SWB has the dash with only a speedometer, fuel guage, and idiot lights. I have a complete dash with all of the iinstruments on the bottom. What do I have to do to swap the two?
Here are my latest photos of the project.
Updated photos
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 05-08-2004, 06:53 PM   #2
john
member #16
john's Avatar
Smile
Here is a link to the dash swap. Look under the tips heading. John
http://www.webnow.com/GMCPaul
john is offline   Reply With Quote
Old 05-08-2004, 07:21 PM   #3
dinnut
dinnut's Avatar
if you have the whole wiring harness just swap the two wiring harnesses with the dash
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 05-08-2004, 11:39 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What ever you do, don't try to just swap the insterment panels without redoing the harness. (either by swapping the wires or swapping the harnesses out)
I did this when I got my first truck, and my buddy laughed so hard he almost puked.
The dash lights won't work properly, and the needle on the fuel guage will spin about 6 or 7 laps all the way around untill it stops with a puff of smoke.
I didn't find it as amusing as my buddy did.
Old 05-08-2004, 11:51 PM   #5
Hooter
My other Love
Hooter's Avatar
Ya my 70 Monte was the same way, cooked an SS tach dash DOH!!!!!
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 05-09-2004, 11:42 AM   #6
rickh
Wiring harness must be changed as mentioned. Should be able to get one at local salvage yard for 15 bucks or less.
Not hard to do at all.
Rick H...
Rick H....
69 C10-CST
Wood bed floor full power
70 SWB 425hp HOTROD!
Full power
71 C20 Camper Special
402 full power, factory dual tanks with gauge switch. FOR SALE!
rickh is offline   Reply With Quote
Old 05-09-2004, 11:50 AM   #7
Longhorn Man
rickh, you don't have to swap out the whole harness, there are a few wires that need swapped around on the plug, and a couple other small chainges, but you can retain the stock harness...just a few mods.
Old 05-09-2004, 12:10 PM   #8
rickh
Easier to explain by changing harness than step by step modification of existing.
Rick H...
Rick H....
69 C10-CST
Full power
Old 05-09-2004, 02:11 PM   #9
MACKL
Almost done!
MACKL's Avatar
Thanks for the input. Now I know what will be required when I tackle this job...MACKL
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Old 05-09-2004, 02:48 PM   #10
Vince M
Vince M's Avatar
I did this swap on mine and followed the instructions per GMC Pauls page. It was easy. You need to swap out the temp sensor also. The idiot light kind is different than the temperature gauge kind. They are direct swaps. You'll need a hard line for the oil pressure gauge it is strictly mechanical.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
