Old 07-06-2018, 01:19 AM   #1
GSP7
GSP7's Avatar
81 K20 Ignition key something broke not the key tumbler broke
My Ignition key tumbler broke or something steering wheel will un lock but something broke inside . Key Just twists,, wont bump starter and wont release column swifter or turn ignition on
Just got towed home and pulling the steering wheel not sure if its just the key lock cylinder or what broke
Any experience this broken problem
P.S. I pulled steering wheel, Turn signal parts and then the key tumbler, but it appears something else is broken down inside the coloums
The auto column shifter wont unlock and key just turns loose like something broke down inside. The steering wheel unlocks so you can turn that though
I have a crappy Haynes manual that doesnt say much kinda worthless
(The rack appears to be coming all the way forward and the steering lock releases)( but auto column shifter stays locked and cant move out of park
Any Ideas or linkes
thanks Rick
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
No Snivelers
"No Lowballers, I know what I got"
GSP7 is offline   Reply With Quote
Old 07-06-2018, 02:32 AM   #2
GSP7
GSP7's Avatar
Re: 81 K20 Ignition key something broke not the key tumbler broke
This might have broke. Gotta take it apart further .
No Snivelers
Old 07-06-2018, 07:41 AM   #3
chuychevy82lwb
If you do take it apart be careful with the bearings they are a pain,if you lose them and expensive too. I lost a couple when I replaced that broken part, so I went to the parts store and it was like 80 bucks for the bearings and retainer.
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good "
chuychevy82lwb is offline   Reply With Quote
Old 07-06-2018, 09:40 AM   #4
GSP7
GSP7's Avatar
Looks like I need a pivot pin puller
Where can I get one?
Also need to remove the piviot spring, not sure how yet
Looks like the above picture broken part is the same thing that broke on mine
No Snivelers
Old 07-06-2018, 11:49 AM   #5
Wgesnerjr
Wgesnerjr's Avatar
I have the OTC puller. only like $12 on Amazon. Works like a champ. For the spring, I use a BIG Phillips screwdriver. Push in, turn 1/4 way, let it ease out.
https://www.amazon.com/OTC-7889-Stee...vot+pin+puller
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-06-2018, 11:58 AM   #6
chuychevy82lwb
https://youtu.be/Fuqc1iWG7gA
Old 07-06-2018, 09:59 PM   #7
GSP7
GSP7's Avatar
I just finished putting back together. Local auto parts had a Dorman kit and I got the Lisle #19940 pivot pin puller at there also
Bit of a chore
No Snivelers
Old 07-08-2018, 11:06 AM   #8
Nodnarb76
Nodnarb76's Avatar
While you are in there you may want to go ahead and look into removing the 4 Torx bolts that commonly come loose and loctite them and tighten them back down. If your steering column is loose these bolts are most likely the culprit.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 07-08-2018, 11:16 AM   #9
abig84
abig84's Avatar
I just had to do this a few weeks ago. I do it the lazy way and only do 2 of them as it's more to tear apart to get to the other 2. Did it when I first got my truck like 9 years ago and took that long for them to loosen up again. But doesn't look like I put lock right on them first time around
abig84 is offline   Reply With Quote
