Old 06-22-2018, 01:01 AM   #1
Tonner
Mechanical Fuel Pump Failure
I just put a brand new mechanical fuel pump on the 350 in my '72. Nothing fancy, just a NAPA OEM type. It ran great for maybe a hundred miles and now it's shooting gas out the weep hole. Would the diaphragm have failed that quickly?
Tonner is offline   Reply With Quote
Old 06-22-2018, 01:08 AM   #2
WhiteCST
WhiteCST's Avatar
Re: Mechanical Fuel Pump Failure
It’s happened to me before on my 53 Kaiser. I’ve had a few bad experiences with mechanical Napa pumps. Still under warranty hopefully?
1953 Kaiser Manhattan “Sled”
1968 C10 CST LWB
1991 Trans Am GTA “White Nasty”
2006 Dodge Charger RT
Built TH400 for Sale
WhiteCST is offline   Reply With Quote
Old 06-22-2018, 01:20 AM   #3
Tonner
If I want to keep it mechanical, what's the best one to get?
Old 06-22-2018, 01:26 AM   #4
WhiteCST
WhiteCST's Avatar
I used a precision fuel pump after having 2 failed Napa pumps. Got it from o Reilly’s. Two years and still going strong. Don’t drive the car very much though, too afraid to damage it and parts are almost irreplaceable.
1968 C10 CST LWB
Old 06-22-2018, 05:39 AM   #5
AC Delco
Old 06-22-2018, 08:35 AM   #6
panhead59
And don't forget a fuel pressure regulator. Most fuel pumps put out more psi than the 5-6 psi that a typical carb requires. Causes a lot of carb. problems.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 06-25-2018, 11:30 PM   #7
Myoldtruck
Myoldtruck's Avatar
same problem here with a auto zone fuel pump. I installed a a/c delco pump and no more problems.
Myoldtruck is offline   Reply With Quote
Old 06-27-2018, 03:08 AM   #8
Rufas
Rufas's Avatar
I've had great luck with Holley fuel pumps. 7.5 psi no fuel regulator required.
Holley Mechanical Fuel Pumps 12-834
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 06-27-2018, 03:53 PM   #9
OregonNed
OregonNed's Avatar
Or even an Edelbrock - mine works great - no regulator for the carb.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-27-2018, 05:41 PM   #10
4carbcorvair
Originally Posted by Tonner View Post
NAPA OEM type
You found the problem.
68 K20 Custom Camper/CST Wrecker.
97 GMC K1500 short bed reg cab.
4carbcorvair is offline   Reply With Quote
Old 06-27-2018, 10:42 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
Had the same thing happen to me a few months ago. Old pump [350 V8 in '71 GMC Jimmy] worked about 11 years, then gave out in downtown rush hour traffic. Got towed home. Replaced it with one from O'Reilly's, and got about 100 miles before it was showering the lower engine bay with 93 octane gas! China. Got towed home again, and got my money back from O'RAP, then got a Delphi from AutoZone. They assured me it was made in Troy, Michigan. As I was applying RTV to the gasket, I found the fine print on the box: Korea. But it works OK so far.
They just don't make 'em here anymore. [That may change due to politics, IDK.]
Where they are being made, they ain't making them right, for the most part.
I think it's a plot to make us all drive Priuses.
Old 06-28-2018, 11:39 AM   #12
Fldawg
Fldawg's Avatar
get a carter if you can find them, don,t know if holley or edelbrock bought them out
"Send in the clowns the goats are loose"
Fldawg is offline   Reply With Quote
Old 06-28-2018, 10:03 PM   #13
'68OrangeSunshine
That's what I had -- that lasted 11 years or so. I could not find a new one locally.
Federal Mogul bought Carter out, but still marketed Carter AFB carbs. I looked for a new AFB in 2005, but had to get an Edelbrock. I haven't seen a Carter mechanical pump in years. I hope it's just me and I've been looking in the wrong places. But I dunno.
Old 06-28-2018, 10:36 PM   #14
Fldawg
Fldawg's Avatar
jegs and summit sell carter fuel pumps just checked, do a google search carter fuel pump
Old 06-28-2018, 11:40 PM   #15
'68OrangeSunshine
Thanks. I should get one to keep in the between-the-seats-console just in case my Asian one decides to join its most honorable ancestors.
Old 06-29-2018, 02:26 AM   #16
stsalvage
Scrapper 1
stsalvage's Avatar
Can I say this two word's CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico
stsalvage is offline   Reply With Quote
Old 06-29-2018, 12:59 PM   #17
Arnulfo
I have a electric fuel pump installed inline before the mechanical. I have had the same proplems with the mechanical types.When they die, its always in traffic. So now when that happens, i just flip the switch to the electric and im good to go. Mechanical fuel pumps of today are unreliable.
Arnulfo is offline   Reply With Quote
Old 07-09-2018, 01:49 AM   #18
mike16
I bought cheapo pumps from several vendors, 20 bucks they cost and they lasted about 3- 7 months. paid almost 50 dollars and it lasted 6 years......
mike16 is offline   Reply With Quote
Old 07-09-2018, 07:16 AM   #19
jjzepplin
jjzepplin's Avatar
I use Carter electric. Flip the switch, wait about 10 seconds, Pump the pedal twice and it lights right up with a turn of the key after sitting for weeks. Been using these for 30 years. My old 58 has a mechanical for nostalgic reasons but that is the only car I cannot get to run right. I am having all sorts of issues with pump pressure and the Edelbrock carb.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
