![]() Join Date: Mar 2012
Request for dimensions
I'm looking for center to center dimensions for the two bolts which hold the steering arm to the backing plate for 3/4 or 1 ton TF trucks. AD may be the same as one parts manual appears to show the same RH steering arm from 46-57.
Thanks in advance. |
Re: Request for dimensions
Does anyone happen to have an axle around that can get these measurements? I'm not finding any locally.
Thanks, |
frankenstien Fabrications
what are you needing ?
frankenstein Fabrications |
![]() Join Date: Jul 2007
He needs center to center on the lower bolts that hold the steering arm and backing plate on. TF 3/4 ton.
What Mr48chev said.
Thank you. |
