01-30-2018, 02:27 PM | #1 |
Panhard Bar
Is there any panhard bar kits beside ccp deluxe panhard that clears a TA 12 bolt rear cover? I’m also looking for 5” drop rear springs with a firmer spring rate that the CCP for a 69 c10. I’m getting bad wheel hop with my recent extra power. I have nice Viking double adjustable shocks but I’m thinking the current springs are to soft and need more spring rate.
2011 ctsv - 9.67@147 2002 camaro - 7.89@174 2002 camaro - 8.47@ 162 street car 2002 duramax - 12.6@105 2009 corvette - 7.96@175 1969 C10 - LS3 LSA blower 10.4@131 |
01-30-2018, 08:20 PM | #2 |
Re: Panhard Bar
Not sure on the panhard bar. Tighten up the rear shocks. That should help you wheel hop.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-30-2018, 08:21 PM | #3 |
motor exploder
Re: Panhard Bar
The Hotchkis rear coils are pretty firm, I'm currently running them on my truck but they are 6" drop, so that probably doesn't help you. Hotchkis included spring plates to adjust the ride height a little bit though. They don't beat you to death on the highway, but they definitely feel firmer than stock springs I had before lowering the truck. They are rated at 380#/in. I'm running Chassisworks DA Vari-shocks on damn near full soft too. I have never tried CPP's rear springs, so I don't know how they'd compare with the Hotchkis springs. I will say I've never experienced any wheel hop at all with the Hotchkis springs, but I don't know if I have what you'd consider 'extra power' - I may not even have enough torque to twist things up out back.
On a side note, GMC Pauls offers drop springs that they can get different springs rates on. If you know what rate you want, you could also get some custom springs wound too. As for the panhard rod, I don't know that either, I'm running the CPP deluxe bar with the Moser Engineering version of the T/A cover you speak of. Everything clears just fine.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 01-30-2018 at 08:27 PM. |
01-30-2018, 08:32 PM | #4 |
motor exploder
Re: Panhard Bar
Dynospeed - After looking at those 1/4 mile times in your sig, I'm sure you'll be able to figure something out
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-30-2018, 09:53 PM | #5 |
Re: Panhard Bar
The stock length adjustable clears the LPW Ultimate-12 cover well. Both covers are of similar profile.
01-31-2018, 10:50 PM | #6 |
Re: Panhard Bar
I'm running the porterbuilt panhard bar and would buy it again in a minute. New frame mount out a little farther and lower, and it attaches all the way over to the other side at the backside of the u bolt/shock mount area. This kit worked with the stock c-10 rear end and also works with my ford 9" rear end in it now!! Nice heim joints on each end with lock nuts and you can lengthen/shorten it's length with one wrench and your hands. Also. remember that you want the panhard bar to be parallel to the rearend at ride height. The porter built kit gives you three mounting holes on the passenger shock location. Travis at Properformance.com will fix you up, fantastic to deal with.
07-10-2018, 07:32 AM | #7 |
Re: Panhard Bar
CPP makes heavy duty spring but i believe only in 3 and 4". then you can use a block to lower. summit racing number is CLP-RCS603-4HD. How do you like your Viking double adjustable shocks? Im thinking of purchasing a pair. also is there any other shock you have used and like? Thanks.
