Closed Thread
Old 07-13-2018, 06:27 PM   #6951
Boog
laying low
Boog's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by OregonNed View Post
The clutch pedal is gone, so a larger brake pedal pad was in order. The gas pedal to match eventually.
Care to share the low down on the brake pedal swap?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 07-13-2018, 06:54 PM   #6952
Steeveedee
Who Changed This?
Steeveedee's Avatar
Going to flush the cooling system. Changed the heater hoses, since they've been on there for 10+ years, and had cheesy shutoff valves in them that my FiL installed. I don't know why, since they were open and the heater core doesn't leak.
Looks like I need the kick panel vacuum actuator. This is for the flap that regulates inside or outside air for the AC. Anyone know a part number other than the LMC or other aftermarket vendor? It lives (and died) at the top of the heater core, just above the heater hoses. I'd like to get it done with locally sourced parts, but ain't having much luck finding one. Went to a local parts store, and the guy started looking through the vacuum advance pix for it.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 07-13-2018, 08:43 PM   #6953
stevenfromtexas
stevenfromtexas's Avatar
Originally Posted by Metaldoc View Post
Looks great, try not to spend time on the edges as the buffer can burn through the paint. As you buff the flat sections stay off the edges, by the time you get a good shine on the flat the final buff will do the edges. Some guys tape over the sharp edges just in case.
yes sir. thank you for the reminder. it was pretty intimidating. started on the lower areas "just in case" haha got through the "black pad/black lid" today. very happy with the subtle changes. gonna do the "blue pad" tomorrow.
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline
Old 07-13-2018, 08:51 PM   #6954
beaterku
beaterku's Avatar
Test fit the rotor and caliper. Wilwood said these calipers would not fit with the CPP modular spindle. They fit like a glove! Buttoning this up tomorrow so it can go back on the ground for the first time in a couple of months.
beaterku is offline
Old 07-13-2018, 09:03 PM   #6955
stevenfromtexas
Originally Posted by bill3rail View Post
How bad were the imperfections and what 3M product did you use?
im a rookie and i have an unconventional paint system. i bought a turbine spray rig from TpTool a year ago. the cap pressure is very low and i did not reduce the epoxy enough according to the guys i bought the sprayer from. the clear sprayed pretty orange-peely too. lots and lots of wet sanding. i actually enjoyed the experience, watching what looked like the moons surface smooth out to at least a 10' paint job.
here is the 3 bottles i got. wool pad with the white lid, black foam with black lid and yes, you guessed it......blue foam with blue lid
Steven
Old 07-13-2018, 10:04 PM   #6956
mygmctruck1
Today , I secured all the new fuel/ brakes lines to the frame , hooked up fuel line to fuel pump , from fuel pump tp carb.
Removed old manual steering box and prepped frame for new PS box.
mygmctruck1 is offline
Old 07-13-2018, 10:10 PM   #6957
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
You're using what I normally use and it's great stuff. I've used it for years and it's awesome.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is offline
Old 07-13-2018, 10:35 PM   #6958
Ol Blue K20
Dale
Old 07-14-2018, 09:42 AM   #6959
stevenfromtexas
i bought some Mequires a while back with harbor freight pads. i couldnt figure out which liquid to use. this stuff is a no-brainer. I'm sold on it!!
Steven
Old 07-14-2018, 11:49 AM   #6960
OregonNed
OregonNed's Avatar
The pedal pad is a Lokar product and very easy to install. I just pulled the stock pad and laid out and drilled four holes for the stainless screws supplied in the pedal arm.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 07-14-2018, 11:51 AM   #6961
OregonNed
OregonNed's Avatar
Going to swap speedo gears to calibrate my speedometer today to actual speed
Old 07-14-2018, 12:02 PM   #6962
not so fast
Looked at the eBay ad over and over and over, waiting for it to make a long journey to me. Hoping it all goes well
Probably be next Tues. they say and its killing me, no sleep
NSF
not so fast is offline
Old 07-14-2018, 12:09 PM   #6963
weq92f
weq92f's Avatar
NSF
Huh?
Post up the add maybe?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 07-14-2018, 04:17 PM   #6964
bill3rail
bill3rail's Avatar
NSF
Originally Posted by weq92f View Post
Huh?
-klb
Thank you! I thought I missed something there.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline
Old 07-14-2018, 07:45 PM   #6965
not so fast
Just got a call from the transporter, he picked it up today at 10 am and will be here Monday after noon if all goes well. He has one more pickup in Idaho with same delivery spot to here in Havasu, Az.
I will definitely post up some photos, shes a beauty to me
NSF
Old 07-14-2018, 08:26 PM   #6966
OregonNed
OregonNed's Avatar
Swapped in a 22 tooth gear vs. the 20 I had and now my speedo is dead on.
Old 07-14-2018, 08:31 PM   #6967
bill3rail
bill3rail's Avatar
I did that and came a little closer, but not dead on. I need to get under there again to figure out what gear I need.
Old 07-14-2018, 11:59 PM   #6968
VWNate1
VWNate1's Avatar
Exclamation Speedometer Gears
? Any chance of a link to the Vendor whom sells those colored speedometer drive gears ? .
Folks are always asking me where to get them and I lost the link when my old computer crashed and burned .
TIA,
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-15-2018, 02:32 AM   #6969
OregonNed
OregonNed's Avatar
Re: Speedometer Gears
TIA,
Here you go!
https://rover.ebay.com/rover/0/0/0?m...2F131761841557
Old 07-15-2018, 07:33 AM   #6970
Grumpy old man
Grumpy old man's Avatar
I just keep bolting on the chrome and stainless as it shows up, Old school !
Grumpy old man is offline
Old 07-15-2018, 09:35 AM   #6971
Boog
laying low
Boog's Avatar
Dang grump! That's just too purty to actually use. Maybe a nice display model instead?
Boog
primer is finer
Boog is offline
Old 07-15-2018, 09:46 AM   #6972
VWNate1
VWNate1's Avatar
Thanx Ned ! .
I see they're cheaper now too ! .
-Nate
Geezer
VWNate1 is offline
Old 07-15-2018, 10:28 AM   #6973
NoStopN
NoStopN's Avatar
I went to a local all GM truck show yesterday. Imagine what I took pics of most.
https://www.flickr.com/photos/882049...57671200461738
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 07-15-2018, 10:57 AM   #6974
weq92f
weq92f's Avatar
There's one oddity in there that is worth a closer look...
Appears somebody dressed up a late model, single cab chevy truck in 67/68 sheet metal...
weq92f is offline
Old 07-15-2018, 11:07 AM   #6975
Mikes68C10
Mikes68C10's Avatar
Yup, that roof line stood out! "Smooth" is the one-word that came to mind if I had to describe it...
1968 C10 LWB Fleet-Wood, 2-WD, 327, 4-Bbl, Auto, 12-Bolt, Bone Stock. >POOF!< Sold 9/8/2018. New owner is local to Waynesboro PA and will take excellent care of her. He also owns a 69 Z28 SS Option car.
1998 Camaro SS, LS1, A4, 3.42. Free Tune - Stock 13.08 @ 106.55 >Lightening Strikes Again!< Sold 9/9/2018 she too will be well cared for as 1 of 45 produced in blue, with Auto and no T-roof.
Mikes68C10 is offline
Closed Thread
