Old 04-04-2018, 04:31 PM   #1
craneboy72
craneboy72's Avatar
Inside tire carrier
Can someone tell me what the max tire size an interior carrier on a 71 Blazer fit? I wanted to put a 12:50 33” on it if I will fit.
craneboy72 is offline   Reply With Quote
Old 04-04-2018, 05:13 PM   #2
SeventyOne
Re: Inside tire carrier
Don't know the answer. I'd assume probably since 31's fit on it, right?
I wonder if anyones moved it to the right and centered it behind the rear seat for more clearance. Could look cool.
SeventyOne is offline   Reply With Quote
Old 04-06-2018, 09:12 PM   #3
Green Monster
Green Monster's Avatar
Kind of... I have a 33" x 12.5 R15 in my 72 and because the tire wheel combo is taller the inside of the wheel slips over the top of the carrier. The sidwall of the tire should press against the carrier. As a result, the tire presses against the back of the rear seat. I can hear the rubber of the tire rubbing against the seat while driving- it squeeks.
I see two options to to address this;
1.Fabricate an extension to add to the top of the carrier might address this issue. I haven't tried it yet.
2. Or you could take the carrier apart at the weld, move the top half up an two inches, weld the top back on and it would look stock.
The larger tire does not interfere with the CST side panel. It is a bigger tire than stock and will significantly obscure your the view from the rear view mirror.
The 33 x 12.50 will fit but slight modifications should be made to ensure it is secure.
To answer your question, it will physically fit, but modifications should be made for it to fit securely. A tire breaking loose inside the vehicle during a collosion could be fatal.
Green Monster is offline   Reply With Quote
Old 04-07-2018, 12:09 AM   #4
2006gmcdmax
I'm curious whether a 15x6 inch wheel with a 33x10.50 R15 tire will have any issues.
2006gmcdmax is offline   Reply With Quote
Old 04-07-2018, 04:25 AM   #5
Harold Holbrook
I have 33 on my 71 Blazer and they look good
Harold Holbrook is offline   Reply With Quote
Old 04-07-2018, 10:28 AM   #6
simicrintz
I'm no tire pro, but that rim size seems a little skinny to me!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 04-07-2018, 10:30 AM   #7
2006gmcdmax
15x6 is the factory wheel size. It's just the spare, I would like to keep it as compact as possible.
Old 07-10-2018, 08:12 PM   #8
rsavage
rsavage's Avatar
If I remember correctly, on my 71 I had only a 235 X 15. It was just for looks because I had an original tire cover. Had 31's on the truck. You can see how close the tire is to the side. I doubt if anything larger would fit if correctly bolted to the carrier.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 07-15-2018, 08:54 AM   #9
jondancer
Anyone selling a spare tire carrier?
jondancer is offline   Reply With Quote
Old 07-16-2018, 05:55 AM   #10
tmontg01
tmontg01's Avatar
There was one for sale recently on ebay
1968 C10 SWB 400SBC with VN327 20's
1972 K5 Blazer 383SBC
2011 Cadillac CTSV
tmontg01 is offline   Reply With Quote
Old 07-16-2018, 07:22 AM   #11
1970cstblazer
1970cstblazer's Avatar
Mine has the 10-16.5 option, and the spare fit easily.
Old 07-16-2018, 12:38 PM   #12
craneboy72
craneboy72's Avatar
Mine came with the same option. did not try fitting a 33" 12.50 tire in there yet.
