Old 07-07-2018, 06:56 PM   #1
65 GMC
Champion radiator ?
Can I run a stock shroud with the Champion radiator in my 64 C20 or do I need to run a electric one?
65 GMC is offline   Reply With Quote
Old 07-07-2018, 07:52 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Champion radiator ?
Shroud or fan?.....if your gonna use a electric fan I'd just use champs.....you can get a pretty good deal on champs radiators with the fan and shroud already setup.....I'm fixing to get a combo here shortly myself...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-07-2018, 08:32 PM   #3
guy0783
I put a 3 row champion radiator/shroud/fan combo in my K20 about 6 months ago with a 185 degree fan switch in the water neck.
Temp hasn't gotten above the middle of the gauge even in the 95 degree 95% humidity we've had in Oklahoma lately.
But with the 4 speed and 4.56 gears I cant say I spend much time at highway speeds.
guy0783 is offline   Reply With Quote
Old 07-07-2018, 08:35 PM   #4
Clyde65
Clyde65's Avatar
Yes you can! I had that before my LS swap
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-08-2018, 01:33 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.speedcooling.com/1963_196..._Radiator.html Check these out before a champion radiator. Champions are pretty good. I do have one in my bb truck and with just a fan it cools ok. It is also a 4 row not a 3. The 3 was way to small for the BB,. This is one with there dual fan and shroud set up. http://www.speedcooling.com/1963-196...um-Shroud.html
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-09-2018, 03:42 PM   #6
66K20
66K20's Avatar
Champion has a few radiator options for our trucks. If you pick one that is sized like factory, you should no problem using your factory cooling equipment, if desired.
The Champion EC284 (2 core, economy) is identical in size to the factory radiator in my 66 K20 with 292, with exception of being 1" taller. The total core thickness of the Champion is the same as the factory 3 core.
Brett | 1966 K20 - 292/SM420/T221
66K20 is offline   Reply With Quote
Old 07-13-2018, 06:56 PM   #7
karlbenz
if you go to their site they have multiple options available. more so than on ebay. check out american eagle too. It's also Champion but has other options
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 07-14-2018, 12:39 AM   #8
AcampoDave
AcampoDave's Avatar
I know electric fans free up horsepower and all that, but I have no problems with an 18" six bladed clutch fan with a Hayden heavy duty clutch and a radiator from speedcooling.com I still use my o.e.m shroud too
AcampoDave is offline   Reply With Quote
Old 07-14-2018, 10:32 AM   #9
LVPhotos
LVPhotos's Avatar
I took the fan and clutch off the 98 Durango 5.2L(318), it was over 20lbs. Now to say hp is saved and letting the weight off the water pump and letting the motor breath a little easier is different. I would not run an electric on my diesel I have come to trust them more after running in the desert prerunner all day.
But I will keep my copper V cell over aluminum til it dies.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-14-2018, 08:38 PM   #10
AcampoDave
AcampoDave's Avatar
https://www.motortrendondemand.com/d...ut/0_olymz420/ really good stuff here.
Old 07-15-2018, 02:10 AM   #11
63burban
Chevy addict
Installed a Champion 2 core aluminum radiator with a factory fan shroud in my Suburban. Running a 90s tbi 350 with a clutch fan, runs great with the ac on and never gets warmer than the thermostat 195 degree
63burban is offline   Reply With Quote
Old 07-15-2018, 09:00 AM   #12
Rich 5150 69
Rich 5150 69's Avatar
3 row champion with factory shroud and fan. no issues
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-15-2018, 03:56 PM   #13
65 GMC
Thanks for the input guys, that's exactly what I was looking for. I ordered the Champion 2 row with 1" rows, it showed up on Friday. After looking at it, I think everything is going to work out as I had hoped. I plan on running the short water pump on my 350 with a fan and clutch from a 66 Impala I parted out a while back.
