Old 07-14-2018, 03:20 PM   #1
63frankintruck
Radiator Core Support Bushings?
I'm looking for core support bushings for 63 C10.
I think they just leather pads in there when I pulled it apart years ago. What are you guys using?
Also is there a place to get them where I dont have to pay more for shipping than what the parts cost?
63frankintruck is offline   Reply With Quote
Old 07-14-2018, 06:39 PM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Radiator Core Support Bushings?
Best off make a list of parts you need and buy them all at one time Then the shipping it more better
stsalvage is offline   Reply With Quote
Old 07-14-2018, 07:06 PM   #3
Short 3/4
Short 3/4's Avatar
Assuming that the 63 uses the same ones as 64,5,6 which is what I'm familiar with, Be aware that the top and bottom ones are slightly different. Factory bottoms have a divot to clear the rivet, while tops do not. Some aftermarket ones do not have this feature, so is worth paying attention to. A correct bottom will work fine on top, but a top will not fit well on the bottom.
Hope this all makes sense,
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 07-15-2018, 12:29 AM   #4
Captainfab
60-66 Nut
The radiator support bushings are the same '60-'68.
https://www.classicparts.com/1960-68...info/78%2D625/
Old 07-15-2018, 07:37 PM   #5
Short 3/4
Short 3/4's Avatar
Where the heck do those go? I thought he was talking about those U shaped rubber thingys.
292-SM420-T221
Old 07-15-2018, 08:43 PM   #6
PGSigns
PGSigns's Avatar
They go between the core support and the frame rails.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-16-2018, 12:41 AM   #7
Short 3/4
Short 3/4's Avatar
Jimmy
Oops, I was thinking of wrong part,
Never mind.
292-SM420-T221
Old 07-16-2018, 09:43 AM   #8
Robert Haas
I built these out of aluminum, did not see the need for isolation.
Robert Haas is offline   Reply With Quote
Old 07-16-2018, 09:52 AM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
And you could sell those "if" they were the correct height for every truck. I dont know the answer to that myself.
