Old 07-16-2018, 03:03 PM   #5
mikentosh
mikentosh's Avatar
Re: 78 GMC Steering column
Glad you got it. Its quite tough to describe...easier with pictures. I found its best to have the section of the column containing the key separated from the rest of the column, then get the gear and the rack lined up correctly (on the right tooth), then gently install the ignition key tumbler into that section and onto the gear (which will hold the gear from moving and the rack locked place), then you can slide that section back down over top of the column.
mikentosh is offline   Reply With Quote
column, gmc, steering
