Trying to identify front suspension
Father in law just bought a 51 Chevy 5 window. Thinking this is a mustang ii front in but I'm guessing. Truck has some body roll. Trying to figure out what to do to minimize it and make it handle a little better.
Sorry the images are upside down
Bagged 1959 GMC 1969 C-30 dump My 59 build. http://67-72chevytrucks.com/vboard/s...d.php?t=592878 |
![]() Join Date: Mar 2011
Re: Trying to identify front suspension
Yes, that is the orginal style MII with the rear brace. You don't have a front sway bar, that will make the front end tilt side to side. Install a sway bar and it will be better. Also the bottom control arm should be paralle to the crossmemer. Someone may have cut the spring, or it isn't heavy enough. You have very little travel with the shock...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 07-15-2018 at 11:26 PM. |
I'll pass this along to him. Are they pretty much all the same for certain years making finding on to fit fairly universal.
I think the MII and Pinto front end was from 1974 to 1978 and were all the same. You can buy parts from many venders. Speedway has lots of different stuff for them...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Never Ending Projects
Agree, MII setup.
To get those to handle and not have bump steer issues, the lower arms need to be parallel to the ground at ride height. If they are stock height spindles, I would replace with dropped spindles and get springs to get the arms back to level.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Jan 2011
That one is going to have some bump steer issues. I would take a measurement on the toe as it sits now and then jack it up three inches and recheck the toe. I think it will pick up 1/4 to 3/8 of an inch. It needs a sway bar and the shocks replaced.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
