Trany question
Hello community,
can anybody help me to identify this trany? Its in my 61 Apache and I think it isn't original. Any owner installed a floor shifter and I want to go back to the tree. I found a 60 steering column and the rods. Can it be done? Do I need any linkage? C164, does it means Jan-16 1964 Thank you for your help. |
Re: Trany question
It may help if you pan the camera out a bit to show the entire tranny. Lots of us can recognize them by their shape easier than their numbers.
Re: Trany question
You can tell by the shift towers and levers.
It’s a Muncie sm 318. Likely original. Your rods will hook right up. |
#4 | |
Re: Trany question
Thank you. |
#5 | |
Re: Trany question
But I think the levers are not original? Am I right? And they are not installed in the correct direction cause the cut the doghouse to make the front lever move freely. It hits the doghouse on the top. |
Re: Trany question
I hope you can see more now. It's not easy.
![]() I cant find a screw or anything to drain the oil!!!! How can I do it? |
![]() Join Date: Jan 2011
Re: Trany question
Those are not the original levers. You will need everything including the levers for the trans to go back to the column shift.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#8 | |
Re: Trany question
Next question, what is everything? Does anybody has a drawing or something like that where I can see how it should look like? rods, linkage??? I'm absolutely new in this. And I'm located in germany, so its very hard to find the needed parts. Thank you. |
Re: Trany question
I just went through this with another member. He had the floor shift and went back to the column shift. I have some pictures I took before I pulled the parts that showed all the pieces and how they went on the truck. One thing that will benifit you in the long run with these trucks is a premium membership to this site. That will allow you to post a wanted ad in the parts section when you need something. The folks here have never let me down when I needed a part.
Jimmy
#10 | |
Re: Trany question
I've changed my account to a premium member now. Hope it works. Thank you. Joerg |
Re: Trany question
![]() Join Date: Sep 2006
Re: Trany question
I have a long tail shaft trans like that in my garage. I think they were in cars but not 100% sure of this. I can take pictures of my tranny and show you the proper side cover for the column shifter. You will need to find a side cover for the column shifter as the levers are different in style and location. My truck has an OD trans, from what I can get from the cast #"s it is a 1957 model trans. I had to use my original side cover on it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
| Bookmarks |
