A/C hose routing
I am converting my 68 gmc 4x4 to A/C but the currant radiator support unit has no provision for the A/C hoses from the condenser through the support unit/.
The hose routing should be the same as a chevy c10 , I am guessing . Anyhow can some one load a pic of where the hoses go through from the condenser? Last edited by mygmctruck1; 07-21-2018 at 01:30 PM. |
Re: A/C hose routing
You could google "Vintage Air 901567" - and download the PDF file from vintage air. This is the install instructions for the vintage air system. They will use the factory A/C holes if they are there, but they give you a template in this PDF file to cut them if not.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
From the PDF, here's the general location...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: May 2010
On my '69.
my 68 C10 with Vintage Air
1968 SWB Step Side, Big Block, 4L80E , Running! |
Thanks guys !
