Old 07-23-2018, 08:47 AM   #11
jimmythompson1964
jimmythompson1964's Avatar
Re: 1966 C10 LB 2wd 283 4spd build
Originally Posted by 66C10LB View Post
Thanks Jimmy! I'm actually quite a newby that this sort of thing, but enjoying the journey. It has been a bit slow, but getting there.
I did not see any bracing, did you test fit your door before you final welded your rocker in place? With all of the metal cut out it can move on so you may want to test fit it now make sure everything is still in line. If this is your fist project you are doing great, and you found the right place to read and learn from, the guys on this site have been there and done that. People on this forum are very knowledgeable and will help you through the learning process. Looks like you are having fun and getting it done.
jimmythompson1964 is offline   Reply With Quote
1966, 283, c10, canada, saddle
