Old 07-05-2018, 03:13 PM   #1
st1
st1's Avatar
Wiper motor replacement
Greetings to one and all. Hope the holiday has been good to everyone and all fingers are still attached. I replaced the wiper motor on my 78 GMC STEPSIDE since the current motor would not stop spraying water. The reman wiper motor from summit worked fine while I was testing it. Then it blew the fuse and another fuse and another fuse. I only switched motors, why is it blowing fuses? The reman wiper motor doesn’t run at all now. I put the original back on and now it’s not running either. It’s summer in N.C. and it will rain. I need dependable wipers, your help is appreciated. St1
st1 is offline   Reply With Quote
Old 07-05-2018, 03:19 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Wiper motor replacement
Fuses are blowing when you power the wipers on?
Blowing out just as soon as you plug one in with the ignition on?
Does the fuse blow with the wiper motor plugs disconnected?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-05-2018, 03:20 PM   #3
st1
st1's Avatar
The fuses blow as I test the motor. Trying to get the arms in the correct parked position. The run I shut it off the don’t run again.
Old 07-05-2018, 03:24 PM   #4
st1
st1's Avatar
I am going to leave the fuse out reset the arms to the correct parked position then install a fuse and see what happens. I have reinstalled the motor that will not stop spraying water. I routed the hoses in a loop so as to not make a mess.
Old 07-06-2018, 07:28 PM   #5
st1
st1's Avatar
So I had to put the old one back on. The reman unit will not run. I will send it back and get another one. Putting the grill back on and calling it done. Grill reinstalled due to another project (a/c charge and trianry switch install).
Thanks for the reply.
Old 07-21-2018, 02:25 PM   #6
st1
st1's Avatar
Got the new reman wiper motor installed with some paint. Looks okay.
Old 07-21-2018, 02:27 PM   #7
st1
st1's Avatar
Pics
Old 07-23-2018, 11:35 AM   #8
rgunlock
rgunlock's Avatar
That looks really nice. Hope you get some years out of it. I recently replaced the wiper motor/pump on my 78 and it worked fine for a few weeks, then started squirting for as long as the wipers were on. Had to pull the water supply hose. I'm hoping to find a better one than O'Reilley's sells next time around.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 07-23-2018, 08:31 PM   #9
MikeB
MikeB's Avatar
Glad your second new wiper/washer worked well. I bought rebuilt wiper/washer assemblies from two different vendors and neither one of them worked properly. Both had intermittent washer problems. Ended up disabling the OE pump and installing an aftermarket pump. So far, so good.
Very nice engine compartment you have there! (Insert simple "thumbs-up" emoji here if I could find one.)
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-25-2018, 06:10 PM   #10
RedBed
RedBed's Avatar
Originally Posted by MikeB View Post
...Ended up disabling the OE pump and installing an aftermarket pump....
I had to do that too. The pumps on the replacements kept getting stuck ON.
I also added a Floor Switch that activates the wipers momentarily for when you just need a couple of swipes - I love it!
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 07-26-2018, 09:43 AM   #11
MikeB
MikeB's Avatar
Seems to be a common problem. Intermittently stays on after you activate it. Or sometimes is on all the time. And since it's mechanical, and not electrical, it's not an easy fix.
I've had mine apart several times and watched it work & fail on the bench (using a 5 amp 13.2 volt power supply). If I could replace a few parts, like the nylon pawl, I think it would work properly. Problem with the re-builder is they probably can't get all the parts, either.
Mike
Old 07-28-2018, 10:35 AM   #12
rgunlock
rgunlock's Avatar
Any detail about how you disabled the OE pump and what aftermarket pump you used Mike?
Rick
Old 07-28-2018, 11:02 AM   #13
MikeB
MikeB's Avatar
Guess I should have taken photos, but what I remember doing is removing the parts in the photo below, and then blocking off the pump plunger with a spacer (but I don't remember what the issue was).
Here's the pump: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Well, heck. PictureTrail won't let me upload any more photos unless I pay an annual fee to upgrade.
Send me a PM with your e-mail address and I'll send you photos of the parts I removed and the finished installation. No fee required!
Mike
Old 07-28-2018, 03:22 PM   #14
rgunlock
rgunlock's Avatar
Thanks Mike! Sorry OP if this is a hijack of your thread, but hopefully it will help others. The first pic is the pump Mike linked, then pictures provided of the parts removed to disable the OE pump, and his installation of the aftermarket pump.
Rick
Old 07-28-2018, 03:29 PM   #15
hatzie
Moderator
hatzie's Avatar
A Dorman 603-131 tank with the AC Delco 89001120 pump are the stock 85/86 CK parts. IIRC the tank fit on my 1976 washer tank mount.
Rather than the Tee you can use a Wye in the washer fluid lines to avoid the U shaped bend. VW # 1J0955873D will work if you can't find one on the HELP rack.
The 98-07 GMT800 washer pump and reservoir GM 1288113 will likely fit next to the radiator on the radiator support. They hold around a gallon of fluid. You'll need to liberate the Metripack connector from your donor but these look fairly attractive to me.
The other part that might be attractive is the combination Washer and rad overflow tanks off the later model GM Astro Safari vans.
Take your tape measure to the Pick-N-Pull.
Old 07-28-2018, 06:12 PM   #16
MikeB
MikeB's Avatar
That's good to know.
Wow, $12 for that little guy. My setup works as good or better than the Rube Goldberg OE pump, so I'll stick with my tee fitting.
Forgot to say the way it works is I just push the OE pump button for as long as I want the pump to run. Looked into a 12 volt timer to make the pump run for a few seconds after pushing the button, but it was kinda pricey.
Mike
Old 07-28-2018, 11:16 PM   #17
hatzie
Moderator
hatzie's Avatar
Those Wyes are in the A2, A3, A4, A5, and A6 Jettas, Golfs, and Rabbits. The B5, B6, & B7 chassis and the Faux Beetle. The Audi models based on the VW A chassis had em as well. Just snag one used.
