![]() Join Date: Aug 2013
Help Stuck Key in Rear Dually Hub
Can someone offer advice on how to get a stuck key out of the rear hub on my 80 dually? I want to look at the brakes but cant do anything until I get that little bugger out. I've tried a magnet, patiently tapping from side to side with lots of WD40 (it moves and the lock nut moves as well), I tried heating it with propane, I tried drilling into it to tap a screw, I tried welding a nail on to it, I tried cutting the retaining lock nut - nothing has been successful and I've spilled two beers and cut my thumb and am getting to the point of "hulk smash." I think that maybe it might have been tapped in and the back side might be mushroomed a bit? I can't figure how it is stuck in there. Thanks for any ideas? - mark
'80 K30 c&c std cab dually (CKM33AB 10000 GVW) D60(4.10)/350 crate/400/205/14 |
Re: Help Stuck Key in Rear Dually Hub
maybe not the preferred method, but Dremel with 1/4" carbide burr did the trick
Ouch.
