Old 07-06-2018, 08:00 PM   #1
MiraclePieCo
MiraclePieCo's Avatar
Fender installation predicament
If you've seen my progress on the "What did you do with your truck today" thread, you'll note the I just installed my inner fenders. Trouble is, there appears to be no way to get the outer fenders on over the inners.
Should I bolt the inners/outers together first and then install both as a unit?
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-06-2018, 08:31 PM   #2
MARTINSR
MARTINSR's Avatar
Re: Fender installation predicament
When I saw that post I was thinking the same thing, I believe the inner fenders have to be on and they are installed as an assembly.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-06-2018, 09:27 PM   #3
MiraclePieCo
Brian
Question asked and answered!
After fiddling all morning struggling to install the outer fenders, I finally gave up, tore everything apart and bolted the inners and outers together as a unit. Result: fenders were installed in 5 minutes.
Old 07-07-2018, 12:04 PM   #4
mr48chev
mr48chev's Avatar
I think I remember going though that over 30 years ago but I always seem to have to do things twice because something doesn't jive the first time.
My ongoing truck projects:
Old 07-11-2018, 10:17 AM   #5
vintovka
vintovka's Avatar
I have found DIY actually means DIO (do it over --and over). Perseverance wins the day
vintovka is offline   Reply With Quote
Old 07-19-2018, 11:00 PM   #6
evilokc
I installed my passenger fender over an already installed inner fender. if I remember right you have to remove the bolts on the top of the core support because the fender slides under there. if your fenders are painted though I wouldn't do it. you WILL scratch them. its messy. as a unit is the best way.
evilokc is offline   Reply With Quote
Old 07-20-2018, 09:38 AM   #7
gigamanx
Looks like you figured it out, but I did notice in your first pic that the core support bolts that attach the inner fender were already installed. One of those bolts goes through the outer fender.
I did mine with the inners installed, but you have to keep all the bolts loose until everything is in place. There is a surprising amount of moving and twisting to get all the holes to line up.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 07-25-2018, 12:11 AM   #8
nvrdone
when I installed my front fenders, I fought with it for a long time. then my wife suggested I assemble everything on the garage floor. we did that, removed the front wheels & 3 of us were able to lift the front clip up and drop it right in. some times she scares me with how smart she is.
nvrdone is offline   Reply With Quote
Old 07-25-2018, 02:47 AM   #9
MiraclePieCo
I frequently ask my wife's advice on car builds. Being a non-participant, she has a different way of looking at things than me, and sometimes that's what it takes to solve a problem.
Old 07-25-2018, 09:49 AM   #10
MARTINSR
MARTINSR's Avatar
YEP, that can work!
Brian
1948 Chevy pickup
Old 07-25-2018, 10:51 AM   #11
mikebte
If anything is worth doing, It is worth doing twice. I live and breath by that, or at least it seams to be the norm.
Every once in a while mine is the same way. I'll ask some random question and she will remember the answer better than myself.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 07-25-2018, 11:28 AM   #12
vintovka
vintovka's Avatar
DIY = DIO (do it over) perseverance wins the day.
