#351 |
Re: "Albert" -- 1949 AD, S10 Chassis
I just read though your thread and just wanted to tell you great job. I started my build and there is so many tips and tricks that im going to use like your cab and box mount.
My question for you is I have an 85 s10 frame. I'm going to do the blazer brake upgrade. Is there a hub to get without the abs hook up? Also is it possible to use the stock s10 hardlines and flex hose with frame mounts with the blazer caliper. Thanks Last edited by 52ratrod; 01-16-2018 at 04:28 PM. |
#352 |
Hussey:
I don't have the rad yet but would like to modify the rad mount now to set up the front end positioning. Would it be possible to get the final height of your rad mount frame (bottom of the 2 x 3 angle you added to a good top reference point). I plan to go with the same rad and fan combination as you did so it should all just slip in when I do get them. The cab mounts are ready for final welding and I am going to add the 1/4 inch to the height as you suggested. Your build is definitely inspiring and the nice weather we are having here lately has me in the garage daily. Brendan |
#353 | |
However, I would highly recommend getting your radiator first before doing any cutting. It's not too pricey of a part from Summit and they can have it to you pretty quick. That way you know for sure you'll be right on. Good to hear it's working out for you. I had some serious dumb luck on where my mounts landed. The bottom of the 2x3 on the front core support is just barely over the front gear box, any lower I would have been in trouble. Adding the 1/4 to the height should be just right. |
#354 |
Perfect. I think you are right and I will go ahead and order the rad and fan next week to be on the safe side. I'm just itching to put the fenders in place and stand back to have a look. The cab mounts are were all tacked together today so they will be test fitted in place tomorrow.
Thanks again for the help. Brendan |
#355 |
![]() Join Date: Sep 2016
my issue with the radiator, radiator support, and fenders, is that you won't know exactly where it sits until AFTER the hood is on. To get the hood gaps right, you have to be able to lower and raise the core support to get the right fitment. Take your time, its worth it in the end. I had to do mine twice because the first time I got everything tacked in and together with just the fenders and no hood. When it was time to put the hood in, I was a whole inch too low for the hood to close and have even gaps across the fenders.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#356 |
Great advice on lining up the front end. Hadn't thought about the hood not sitting right. I will definitely fit it all together before building the rad lower support.
I bit the bullet and placed my order from Summit this morning. The rad and fan should be here by the end of the week. The front mounts took a little persuading and trimming to fit the narrow part of the cab front but the cab mount locations are exactly where recommended and are ready for welding up and then permanently welded in place. The two inch location from the oval hole was a great reference point. I think the cab actually sits nicer now than it did on the wooden blocks. Could I ask for a couple of more quick measurements? Getting a bit ahead of myself but what is the length of the bed rail tops and how far from the cab is the front of the bed? The reason I ask is that I am considering getting a blazer gas tank for behind the axle. I have a long bed that I am going to shorten to a short bed. It currently has four stake pockets on each side. I'm hoping to cut off one end next to the third pocket and still end up with the correct length short bed sides. Also, trimming the chassis frame as you did may not leave enough room for that tank. The stock tank location may be the best route to go in the end. Thanks again. The help you guys have provided here is definitely making this project fun. Brendan |
#357 |
the blazer tank will fit behind the axle. you'll cut about 5" off the rear of the frame if its an s10 long bed single cab. You will have to rework your rear xmember. save your extra stake pockets and sell them. people would def want them. I had to make one from scratch one time. With the rad, the front fenders should be level and that should put you in the very close ball park. but yes hood fitment is a good practice. You could also just make shims for your core support if the whole thing needs to come up.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#358 |
Sorry, I neglected to mention that the donor truck was a 2000 extended cab short box. I had to shorten the frame to get the correct wheelbase. After a long search, it was the only half decent truck I could find in my area. We use way too much salt on the roads in the winter so the older ones are long gone.
#359 | |
#360 | |
#361 |
Posting 119 has the wheel and tire size on this build. They definitely look great.
I am considering Dodge Ram 20 inch rims with slightly lower profile tires and using GM to Dodge adapters. I really like the looks of them, they have very little offset and I need spacers anyway. By the way, my rad support is done and it turned out terrific. Without the pictures posted, it would have been quite time consuming. Now to put the front end together. Brendan |
#362 | |
#363 |
Thank you Sir.
#364 |
1952SSR would you mind sharing your wheel manufacturer, and sizes (front & rear)? Thanks!
#365 |
I went with Boss 338 w/ spinners.
20X10 / 255-35-20 on the rear 18x8 / 225-40-18 up front. Changing tire sizes in the future to 275-35-20 on rear wheel and tires on front to 18x9.5 on 255-40-18's. That's the combo I have on my '53 I'm building now. I like the look much better. |
#366 | |
#367 | |
#368 | |
#369 |
Are you using the s10 swap mounts? What about the cooler for the motor oil did you eliminate it or hook it up?
#370 |
On my build, I was 1/4 inch from the firewall on the passenger side. After much thought and measuring, I decided to recess the firewall 2 inches. The whole thing worked out perfect with extra valve cover clearance and the wheels now centered in the fenders. This also allowed me to move the cab mounts forward 1 inch while also gaining 1 inch of clearance behind the engine. It actually didn't take that long to do once I got rolling.
Brendan |
#371 |
Had to think about that for a bit. So, I followed the oil filter delete suggestion I was given when building out the engine. there is an adaptor plate that does two things 1. Allows you change the oil filter to be vertical making changes much much easier. 2. Deletes the oil cooler line.
I found my invoice for Jegs.com 599-HP-2002 K&N filter 809-3951644 Oil filter bolt 809-19299222 Oil filter adaptor Not a good pic, but you can see the K&N filter installed. It was a super easy mod and I've been very happy with the performance. ![]()
#372 | |
Is there any difference in height for a 1952? I used these plans for mine and now I am 2nd guessing myself. I plan on trying the cab on the frame tomorrow.
#373 |
Thanks. I will probably just eliminate it. |
#374 |
Missed your other question...I used Transdapt 9926 S10 motor mounts.
![]() Jegs has both a kit with pads and a kit without. My pads looked fine, so I didn't bother with those. Just got the plates to mount the SBC. https://www.jegs.com/i/Trans-Dapt/969/9926/10002/-1
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 07-27-2018 at 09:58 AM. |
#375 |
Hussey,
Do you have a part number for the 2” hub centric spacers? I have been looking all over the internet and everything I find says they are not for use with 2wd blazers. I am building a 53 and pretty much copying most of what you have done. |
