07-24-2018, 11:35 AM | #1 |
C10 CLUB Y QUE!
6 lug disc rotor
Any way to buy them locally? With out having to buy them online
Calipers you can buy at your local parts store. But the rotor I'm having an issue finding them. I'm working on buying the spindles online or shopping on craiglist |
07-24-2018, 12:39 PM | #2 |
Never Ending Projects
Re: 6 lug disc rotor
There is no factory application for this, hence why you cannot buy off the shelf locally. All of the 6 lug conversion rotors are special made for the vendors (either outsourced or done in house). You're stuck buying online.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-24-2018, 01:12 PM | #3 |
67-72 parts collector,…
By from Summit Racing.
CPP brand. Cheapest deal out there with good service from Summit. https://www.summitracing.com/parts/clp-cp4r-6
07-24-2018, 04:50 PM | #4 |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
07-24-2018, 05:38 PM | #5 |
Huh, when I bought my CPP disc brake conversion kit, there was a sticker in the box that said that a later year 6 lug rotor could be purchased to fit. I have a horrible memory and can't remember the year range, but I'm pretty sure it was mid to late 70's c20? Because as long as the rotor is a certain diameter, and 1.25" thick with the 6 lug pattern, you should be able to use any brand. Although I could be way off, I just remember seeing that sticker in my kit.
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck... My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023 |
07-24-2018, 06:50 PM | #6 | |
But Found Her 25yrs Later!
07-24-2018, 09:33 PM | #7 |
C10 CLUB Y QUE!
Thanks guys
07-24-2018, 09:34 PM | #8 |
C10 CLUB Y QUE!
Any suggestion on drop spindels
07-24-2018, 09:43 PM | #9 |
Bell tech, Western Chassis, ECE, or McGaughy’s.
What year truck? What year parts are up front? Still drum brake or swapped already?
07-24-2018, 09:51 PM | #10 |
where are you located?
07-25-2018, 01:39 AM | #11 | |
C10 CLUB Y QUE!
1965 parts Drum still |
07-25-2018, 01:40 AM | #12 |
C10 CLUB Y QUE!
07-25-2018, 05:33 AM | #13 |
You need 63-70 conversion spindles.
The companies that I listed above all make conversion drop spindles. No need to use 71-72 or 73-87 parts.
07-25-2018, 10:46 AM | #14 |
https://www.earlyclassic.com/catalog...&keys=&=Search You can drive down and get them. They bolt up to the stock steering components.
07-25-2018, 06:05 PM | #15 |
C10 CLUB Y QUE!
Correct but im changing ball joints and the 7387 are cheaper
07-25-2018, 08:19 PM | #16 |
Then you have to change all the steering to 73-87 or run tie rod adapters.
You choose where you want to spend your money,...
