Old 05-08-2004, 12:49 PM   #1
pickupman
pickupman's Avatar
Transfer Sleeve Needed
I have a customer looking for a transfer case adaptor sleeve for the rockwell transfer case with a 4spd tranny in front of it. If you have anything please let me know.
Thanks, Bill
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 05-08-2004, 04:54 PM   #2
drink2mny
drink2mny's Avatar
Hey just a heads up, I talked to Randy at Blackbird's. He believes he has a couple of those sleeves, but needs to scrutinize them to be sure they are in good condition..
He said feel free to give him a call and see if he can help you out..
509-534-5219
Support The Board
drink2mny is offline   Reply With Quote
Old 05-08-2004, 09:40 PM   #3
bisquik65
bisquik65's Avatar
sleeve
I have one in my hand right now. It is a psare for my 69 k20 . I am trying to get someone to make these . Extremly hard to find . Took me 3 years to find this one.
bisquik65 is offline   Reply With Quote
Old 05-09-2004, 12:26 AM   #4
J.Lance
Too many is never enough!
sleave
I have an extra. There are a couple of different versions. From memory I believe mine is 3 1/4" long? 10 spline. I searched for months and finally cold called a salvage yard in California and the guy happened to have a coupled rockwell/4spd with a cracked adapter and sent me the sleave for $100. OUCH!! Had to have it though. As luck would have it, my buddy with a 69 Suburban happed to ask at a farm supply store in Nebraska if they had any and they had 2 N.O.S sleaves that had been sitting on the shelf for a couple decades. He bought them both for $40 ea. To make a long story even longer...I installed the new one and I'll sell the used spare for $50 shipped. I have excellent pictures but I'm in Idaho right now and won't be back home until Tuesday. I'll even send it in the original GM box with part number. Let me know.
Jason
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 05-10-2004, 12:05 PM   #5
Yukon Jack
Yukon Jack's Avatar
Just a heads up, if you have the adapter sleeve that is used between the 3 speed manual and the Rockwell T221, you can have it cut shorter and it will work. Same spline just too long. That is what I did for my K20 when I changed to a 4 speed.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-10-2004, 12:55 PM   #6
1969 GMC
1969 GMC's Avatar
I'd let you have mine as I am swapping to NP205...but the transmission end of the sleeve, along with the transmission output shaft are toast .
You might be able to use a NP205 sleeve, but iirc the one for the Rockwell is longer and larger in diameter. I'll go outside and measure mine.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-10-2004, 01:01 PM   #7
1969 GMC
1969 GMC's Avatar
D'oh! I am retarded...I already put the NP205 adaptor and sleeve into my truck. However, the Rockwell sleeve is 3-7/32" long and a hair under 2" diameter, if that helps at all.
1969 GMC K2500
1996 Honda Accord
