Old 07-03-2017, 09:48 PM   #1
pappy 2
Air compressor cooling lines.
Getting ready to fabricate a cooling line system for my air compressor, for air tools and parts painting. Will be using L type copper. My compressor is rated @ 175 PSI. Can I get by using regular solder, or will I need to have sections silver soldered? Thanks for all input.
pappy 2 is offline   Reply With Quote
Old 07-03-2017, 11:11 PM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: Air compressor cooling lines.
My local plumber did mine, not sure what type it was but I think it was just regular as you would use on house pipes.
Jcfcamaro is offline   Reply With Quote
Old 07-04-2017, 01:04 PM   #3
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Regular 95/5 solider will work just fine. It will hold 200 psi without a problem. This is of course if it is soilder correctly.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 07-27-2018, 11:30 AM   #4
pappy 2
Post Re: Air compressor cooling lines.
OK, System has been in for about 3 years now, and have had no issues with leaks or joint separation. Used regular solder.
