Setting Throttle Cable
What's The Correct Procedure To Setup a Throttle Cable?
Posted via Mobile Device |
Who Changed This?
![]() Join Date: Jan 2013
Re: Setting Throttle Cable
What are you running?
The throttle plates should be vertical when the accelerator pedal is on the floor. If you have a Q-Jet or anything else with vacuum secondaries, you'll have to open the secondary air valves in order to check.
Its An Edelbrock Carb With a Lokar Throttle Cable
