Old 07-26-2018, 06:44 PM   #26
chrismoore701
chrismoore701's Avatar
Re: Tired of trans pan leaking
Project update. I looked and i have no vent. I poked around with a small drill bit and seems like the hole is plugged solid. Almost like it is from factory. I assume there is not a chance it would be sealed off. What’s my next step? I have 4000 miles on this since a fresh up that i had a trans shop do for me before i installed the motor.
Thoughts?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 07-26-2018, 07:24 PM   #27
chrismoore701
My buddy said to lift the dipstick cap and let it vent there.
Chris
Old 07-26-2018, 09:31 PM   #28
cerial
cerial's Avatar
The vent tube(check valve) on your th350 is 8-10" above the gear selector seal.
Should be able to run your paw up there and feel it.
If you remove the driveshaft(s) and lower the cross member you can drop the transmission enough to install a tube or replace the check valve. Pull your distributor cap also just to be safe.
Some shops will paint right over the thing or never replace it.
If the thing is 2wd a check valve is alright to run. If 4wd a tube going up the bell and to the firewall will avoid you thinking about another rebuild when you have a water/mud slurry seeping into the cab.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 07-26-2018, 09:54 PM   #29
chrismoore701
The issue is the hole is plugged solid. I can feel it. Concerned about pushing what ever is in the home into the trans. Options?
Chris
Old 07-27-2018, 05:28 AM   #30
S10Fan
Old Heap Driver
Situations like this is why I bought one of these to keep in my tool box............
https://www.ebay.com/itm/6-LED-USB-W...from=R40&rt=nc
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 07-27-2018, 07:34 AM   #31
cadillac_al
Why would a rebuilder plug the vent? Rookie mistake.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-27-2018, 12:17 PM   #32
chrismoore701
That is a good question, I think I might call him, it was a long time ago, but maybe something he knows or normally does.
So the question is, how do I go about getting it open? Stab it with a pick? Drill it out? what?
thanks
Chris
Old 07-27-2018, 12:27 PM   #33
chrismoore701
I called the trans shop, they said they would never seal it, which is what I expected, but look at the pic I found, No breather.
Chris
Old 07-27-2018, 12:54 PM   #34
geezer#99
geezer#99's Avatar
What’s in that vent hole 10 inches straight up from the shift shaft?
Old 07-27-2018, 07:41 PM   #35
MikeB
MikeB's Avatar
Originally Posted by Desert1957 View Post
2 front bolts?
Front pump o ring?
Torque converter shaft seal?
Cracked case?
Iv'e seen a lot of leaks up front sling around by the torque converter, then drip after vehicle sits over night.
Brake clean it off and watch it...
Yes, you are well beyond pan gasket leak.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-28-2018, 07:35 AM   #36
chrismoore701
That is the question. It feels hard as hell. What do i do to get it out? Stab it with an ice pick? Drain the pan and blow air into it? I have a new pan with a drain plug? Or drill it out?
Chris
Old 07-28-2018, 08:57 AM   #37
geezer#99
geezer#99's Avatar
Take a closeup pic.
Post it for us and take it to your tranny guy and show him (if the tranny is still on warranty).
Might just be a soft plug.
Old 07-28-2018, 08:58 AM   #38
cadillac_al
Whatever is in there should be able to be drilled out. If you drill very slow most of the material should be pulled upward by the drill bit and hopefully very little will end up in the trans. It can't be metal so whatever it is shouldn't be terribly harmful and should stay in the pan and the filter won't let it in the valve body. How did the rebuilder not notice this??
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 07-28-2018, 09:05 AM   #39
chrismoore701
Take a closeup pic.
Had it freshened up 4-5 years ago. As you can see from the pic had it done. Dropped on the frame. Then built the truck. On the road 3 years. 4,000 miles. Minor leaks.
Now this.
Chris
Old 07-28-2018, 11:05 AM   #40
geezer#99
geezer#99's Avatar
If ever need to drill anything out and you’re worried about shavings, just put some grease on the drill bit. The shavings will stick to the grease.
Old 07-29-2018, 09:29 AM   #41
chrismoore701
Tearing her apart this afternoon. Any other thoughts before i pull out the scalpel
Chris
Old 07-29-2018, 02:34 PM   #42
chrismoore701
Another question. The front of the truck is 12” in the air and i am catching the drips. So far i have almost a quart. Was is it still leaking? I thought pressure would have blown a little out and after cooling could stop leaking. Did it hollow the seal?
Chris
Old 07-29-2018, 07:21 PM   #43
chrismoore701
Update: i learned some valuable lessons today. Took a couple pics and looked like it was clogged. Found a flexible drill bit that i was able to get the bit into the vent hole. Started to drill. And drill. And drill. My buddy came over and stopped me. Started researching a little more and realize it was not plugged. I was drilling through the wall that is just inside the hole. Dropped the pan. Hit the dipstick tube with a small shot of air. Vent clear. That’s all i needed to do. Checked the pan for square. Front has a 0.034” gap between the bolts. I assume this is the problem. Going to email the company tomorrow. Thoughts on this gap? It’s right where it is leaking. Should i get that lube locker gasket?
Chris
Old 07-29-2018, 09:27 PM   #44
Pontiac1976
Pontiac1976's Avatar
Ok not sure you knew what the vent looks like. But if you look @ the Diff 12 inch rubber tube on right side axel tube at the end is the vent tube check valve ( white or black Plastic).
The same vent tube check valve is on the trans ( white or black Plastic). ( lets gas vaper out keep oil in)
Is this the same old trans pan or the new one? that has the gap.
As for the old steel pan is it pretty straight the seal lip? And does the steel pan have a little ridge on the out or in side dead center all the way around the pan where the hole bolts go.
On the inside or out side lip use a flat punch or vary dull chisel to tap them back out the 2mm to 4mm depth this help seal the gasket & helps the bolts put a little more pressure on the flange. If they been over tighten they maybe flatten out to much on some or all at the area's around the flange.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
