Old 07-24-2018, 07:19 AM   #1
Jstock85
LS to older trans
The hole that happens to be not used on the back of the LS block is exactly where my trans fluid dipstick from the th350 was held on my SBC. Can I just thread the unused hole on the trans bell house and bolt the dip stick in the same place? Or is there another way? Whats everyone else doing that kept the older style trans?
Jstock85 is offline   Reply With Quote
Old 07-24-2018, 09:51 AM   #2
71cadc10
71cadc10's Avatar
Re: LS to older trans
I think I would tap the bell and use a very short bolt
I wouldn't risk drilling a shallow hole in the block, because I don't really know how far it is till water. Must be fairly close or GM would have put the hole there.
unless you have a junk block to do a test on
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 07-24-2018, 10:36 AM   #3
davepl
davepl's Avatar
I am not a guru and I cannot solve this problem but will raise one just to make sure you're aware of the issue.
Between "classic" big and small blocks and the LS motor there is a difference in how far back the face of the flywheel is vs the old motors. It is .450 less further back, I think.
So, to run my LS3 with my old Hayes clutch and TKO-600 trans that come straight off the 502 big block, "all" I had to do was buy a special GM flywheel that is .450 thicker than normal. That is GM part number 12561680 and runs over $400 and there apparently cheaper ways do it with a truck flywheel, etc, but I don't know the details.
So, when I saw "LS to Old Trans" I figured I'd better post this little nugget! What I wouldn't have paid for the knowledge in the previous paragraph, would have saved me some time!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-24-2018, 03:08 PM   #4
Jstock85
Yes def not going to tap the block. Just curious if anyone else was using the bell housing like I am thinking about.
Old 07-24-2018, 03:09 PM   #5
Jstock85
Dave you are correct. I took a dished flex plate from a 4.8 and used to self centering ring. Yes it is complicated I did a ton of research on this same topic.
Old 07-24-2018, 03:31 PM   #6
Kudzupatch
Kudzupatch's Avatar
First thing that popped in my head was to use a flat head screw (bolt). Countersink the face of the unused hole in the transmission for the screw. Put a thin jam nut on the back and with the threads sticking out past it you have stud to mount on.
Kudzupatch is offline   Reply With Quote
Old 07-24-2018, 09:03 PM   #7
Jstock85
Thats a good idea. I may give that a shot first. Thanks!
Old 07-24-2018, 10:57 PM   #8
sprint_9
sprint_9's Avatar
Im running a 4l60e but the dipstick Im using was an aftermarket one that utilized that hole. I cut the bracket off and flipped it around to go to a head bolt hole. Held everything in place and hit it with a quick tack, once it was positioned good I welded it solid and painted it.
sprint_9 is offline   Reply With Quote
Old 07-29-2018, 11:19 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
ICT Billet makes a bracket that bolts to the head and locates a mount in the stock location
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 07-30-2018, 07:15 AM   #10
Jstock85
I guess I should have done a follow up post but I found that bracket on amazon for $20 and ended up going with that.
