Old 07-31-2018, 12:53 PM   #1
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Show us Yer Battery!
I put my battery behind the passenger side on the frame. You really need the bed on to do this so you get proper position. I also put a cut off switch along the way to the starter so I can shut the battery off from the rest of the truck. I only left the stereo hooked up to keep the memory. As soon as I get a new bed I will try and have an access door from the top like I did with the temp plywood I used. I also cut out the old battery box indent on the inner fender. I had to cut up a left inner fender to do it but it wasn't a very good one so I didn't feel to guilty.
If you check out my build thread and go to page 5 that is where the battery box starts.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-31-2018, 04:51 PM   #2
sixty4bigwindow
sixty4bigwindow's Avatar
Chevy, did you buy a kit? Or did you fab up your own box? I love the location of that setup. I'm wondering how the weight distribution of the battery in the middle/rear, along with a tank relocation is affected by these two moves.
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck...
My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023
sixty4bigwindow is offline   Reply With Quote
