Closed Thread
Old 07-29-2018, 12:50 PM   #7051
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today? Chapter II
Fixed the horns and signal self canceler Bought a new turn signal switch but didn't like the modern 4 way button and using an adapter to my wiring. So I took parts from the new one to fix the original. Just needed the spring under the horn contact and the spring for the self cancel. New springs and all is good.
72c20customcamper is offline
Old 07-29-2018, 09:41 PM   #7052
ZEKE68
ZEKE68's Avatar
1. Finished installing the transmission controller and wiring. 2. put the seat and carpet back in. 3. Glued the rear view mirror bracket on three times. ( It came off twice when I went to put the mirror on), ( 90 degrees and raining here today ). 4. Then I started taking out the plywood bed the PO put in, so I can rebuild the differential, install a top mount rear sway bar, and install a real wood bed.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline
Old 07-30-2018, 01:03 AM   #7053
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Degrease and power wash the engine bay of the “Redheaded Stepchild”. Next is to detail in anticipation of the up coming 327 rebuild.
http://67-72chevytrucks.com/vboard/a...1&d=1532926760
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline
Old 07-30-2018, 07:21 PM   #7054
66clow
66clow's Avatar
Bought a $20 Nissan truck car cover for my 69 off Facebook🤣 does the job.
66clow is offline
Old 07-30-2018, 11:17 PM   #7055
Metaldoc
Metaldoc's Avatar
I bought one at Walmart on sale with a crushed box and I never put it on, but then again I've never washed my truck.
Do it, Do it right, Do it right the first time
Metaldoc is offline
Old 07-31-2018, 10:38 PM   #7056
66clow
66clow's Avatar
Hauled the bug home from getting the electricals fixed. It now has lights. Once I finish the interior and flip it, time to get the body work done on the truck to paint it.
66clow is offline
Old 07-31-2018, 11:01 PM   #7057
rkeller411
Finished LS swap...
rkeller411 is offline
Old 08-01-2018, 12:08 AM   #7058
Canuckvetter
Removed the box to freshen up the paint on the frame. Dimpled and test fit the power steering box prior to frame paint.
http://67-72chevytrucks.com/vboard/a...1&d=1533096343
Old 08-01-2018, 08:37 AM   #7059
VWNate1
VWNate1's Avatar
Question Frame Painting
Looks like a good project, how will you prepare the old surface to re paint it ? .
TIA,
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-01-2018, 12:26 PM   #7060
Metaldoc
Metaldoc's Avatar
Blue flame adjustable and a BFH?
Metaldoc is offline
Old 08-01-2018, 09:16 PM   #7061
72c20customcamper
New bearings on the drivers side rotor. And new tires all around. Amazing that they looked great on the outside but in the back side cracked like all hell. But the DOT code was the 42 week of 2010 so they were done. Should have looked when I bought it could have knocked a little off the price
Old 08-01-2018, 10:31 PM   #7062
Canuckvetter
Yes. 2 applications for a precision fit lol.
Old 08-02-2018, 07:34 PM   #7063
NoStopN
NoStopN's Avatar
I knocked off all but one old mount from the flatbed. The last one is welded in multiple places & I need to buy a cutoff wheel.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 08-03-2018, 12:54 AM   #7064
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I didn't do anything to my truck but was on the way home and the City had blocked off a main intersection for road repairs so I went down a back alley and lo and behold there was 68/69 GMC with a canopy sitting in a back yard with 90's Lincoln in fornt of it. Wife was with me so I'll go do some investigation when I'm alone and yes I'll get pics..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 08-04-2018, 06:36 PM   #7065
Already Gone
As promised he is the pic..
Old 08-04-2018, 09:10 PM   #7066
rustytruck50
rustytruck50's Avatar
Well, you've heard about the YouTube videos about the adult dog getting a puppy to play with....I bought Raymond a youthful stepbrother/daily driver today, a '98 Silverado Z71 XCab....no pics now, but will have soon
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 08-04-2018, 10:18 PM   #7067
stevenfromtexas
stevenfromtexas's Avatar
finally found a tricky vacuum leak, with the advise of so many folks on this amazing board!!!
thank you all!!!!, for everything
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline
Old 08-05-2018, 12:33 AM   #7068
BC10
BC10's Avatar
Prep and primer, more prep and more primer, repeat...
BC10 is offline
Old 08-05-2018, 12:37 AM   #7069
weq92f
weq92f's Avatar
Went to check the cam lash and found it would not move at all without deflecting the cover. I have not a clue what might have caused this. Cover comes back off and it will be adjusted again. Gasket was destroyed so now I have another set of waterpump gaskets and a front seal! Yay!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 08-05-2018, 01:22 AM   #7070
PepperTreeGarage
PepperTreeGarage's Avatar
Got the "Stance" right on the "Shop Truck"~~Still much to do~~~~~
PepperTreeGarage is offline
Old 08-05-2018, 10:33 AM   #7071
rustytruck50
Nice!!!!!!!
-Doug
'05 RCSB Sierra 2WD
Old 08-05-2018, 10:37 AM   #7072
rustytruck50
New ride & Blue ride pic as promised....really happy with the '98...need to diagnose a warm engine hesitation & all will be good in the hood
Getting Raymond's timing chain & gears replaced will take care of that nasty disturbance in the force, as well
-Doug
'05 RCSB Sierra 2WD
Old 08-05-2018, 02:26 PM   #7073
ncpetersc
ncpetersc's Avatar
Was psyched to read about your success!!
ncpetersc is offline
Old 08-05-2018, 02:28 PM   #7074
stevenfromtexas
thank you!!!!
drove it to church this morning
Steven
Old 08-05-2018, 02:54 PM   #7075
RodnRudy
RodnRudy's Avatar
Not today but Thursday I met my buddy from Illinois at the Street Rod Nationals in Louisville Ky. Had a real good weekend. His saddle colored 68 with the old topper is very cool.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Closed Thread
