Old 08-03-2018, 05:37 PM   #1
FL71C10
New Brake System - Dot3 or DOT4?
I am completely redoing the brake system in my truck from stem to stern. It's a 71 with factory discs up front, power brakes, nothing fancy.
What type of fluid should I use?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 08-03-2018, 07:14 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: New Brake System - Dot3 or DOT4?
DoT 3 is all you need. You can use the DoT 4. It has a higher boiling point, if that is a concern. I use DoT 3 in my truck, even when pulling a trailer (which has its own electric brakes).
~Steven
Simi Valley, CA
Old 08-03-2018, 09:49 PM   #3
VWNate1
VWNate1's Avatar
Post Brake Fluid Dot3 or DOT4?
Either will work but DOT is what disc brakes call for .
The main thing is to remember to fully flush and replace it every two or three (at most) years .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 08-04-2018, 12:43 AM   #4
kwmech
I put DOT 4 in everything now-a days.
