Old 08-05-2018, 03:38 AM   #3
Project86
Re: Building your own sheet metal bed floor
Originally Posted by cerial View Post
I reused my factory holes and moved my cross beams forward or backward to allow a section of L to be welded to the side of my cross beams then laid the long beams on top.
You have a good 3" to work a wrench under the bed and onto that bolt. The bolt at the front of the spring (2nd set back) either requires a long bolt or using a short bolt and 2 wrenches. I went with a short bolt there.
ah. makes sense. so you utilized the original bed mounts on the frame, just made a support that bolts to it
Project86 is offline   Reply With Quote
