#26 |
Re: trimming lower control arms
Why is the part that I outlined in red left and not removed?
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
#27 |
The material left behind doesn't prohibit any function so it's just an asthetic deal. Remove it if it bothers you. If it doesn't, no reason to do the extra work.
#28 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Bringing this thread to the top for a board member,...
#29 |
Bringing this thread to the top for a board member.
#30 |
Are those spot welds, and if drilled out would the whole assembly just pop off? I'm thinking that might be easier than cutting through the whole thing.
1968 LWB C20 / AC / Wood Bed |
#31 |
![]() Join Date: Apr 2005
Did you try this?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#32 |
No, haven't yet but I'm getting close to the point where I might.
One question though, what about the bump stop? It seems like you'd still want a bump-stop to limit the control arm travel. Otherwise some components would mash together that shouldn't, right?
#33 | |
- Your wheel and tire size - Do you still have inner fenders - How low can you drop assuming airbag failure (if you are bagging it) and still drive Also I came across posts in which people verified that you can just drill the spot welds with 1/2" bit and then chisel the whole thing off.
#34 |
Ok so I did drill through the spot welds with a 1/2" bit and then just beat the bracket off entirely with a BFG. Took all of 5 minutes!
#35 |
Sorry to bring up an old thread...
I'm about to install Belltech 3" drop spindles. Stock 15x6 wheels. I noticed in this thread that the bump stops are cut off. Following this article in HR Mag, they left the bump stops. https://www.hotrod.com/articles/low-...ody-chevy-c10/ I installed Moog 6454 with one coil cut off. It brought the front down 1.5", and it looks like there is still adequate bump stop clearance. For the guys that cut off the bumpstops, did you put anything else there, or leave them off? I'm thinking about trimming it off, then mounting a bolt-on bump stop. This is on a squarebody... |
| Bookmarks |
