Old 08-05-2018, 01:24 PM   #1
FL71C10
rear brake hose union location
I am redoing my whole brake system, and ran into a problem with the rear brake lines. I bought a new stainless line kit from Right Stuff several years ago. I went to install them yesterday and the lines are not the right length. The driver side is too short and the passenger side is too long.
My truck is 1 71 1/2 ton, coil springs.
Here are a couple of pictures. Does anyone have a picture of how theirs are? My tab is broken off the rear end housing so I could some help figuring out where that attaches as well.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 08-05-2018, 04:30 PM   #2
NoNeck
NoNeck's Avatar
Re: rear brake hose union location
You need the brass union that connects those brake lines together. You will also need to install the missing tab on the axle housing because a spring clip attaches at that connection.
Here is a photo that might help.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 08-05-2018, 04:38 PM   #3
FL71C10
Thanks, Pop. The picture definitely helps. I do have the Union as it is part of the brake hose but the tab broke off of the rear end housing. I still have it so I'll just tack it back on. I have ordered some new lines, hopefully they will solve that problem
Old 08-05-2018, 04:51 PM   #4
RustyPile
RustyPile's Avatar
No need to order more lines.. Simply straighten each bend a very slight amount.. You'll gain the "missing length" easily enough..
RustyPile is offline   Reply With Quote
Old 08-06-2018, 07:22 AM   #5
ncpetersc
ncpetersc's Avatar
A little mini hijack, since these pictures are so good. I think I may have this or similar rear end. Been chiseling 45 years of crud off of it to get a better look, but I could not locate a fill hole for it. How do you check level or fill this thing, do you use the vent tube orifice?
ncpetersc is offline   Reply With Quote
Old 08-06-2018, 05:58 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
On the driver's side of the pumpkin, there should be a plug. It should be visible, unless someone really didn't care enough to check the diff once in a while.
Keep scrapin'!
~Steven
Simi Valley, CA
Old 08-07-2018, 07:22 AM   #7
ncpetersc
ncpetersc's Avatar
Keep scrapin'!
I read passenger side somewhere yesterday, but didn't get a chance to crawl under and hunt for it yet. But, yeah, you might be right about someone not caring to check it in a LOOONG while. Going to update my thread with questions so as not to hijack this one to badly.
