Old 08-08-2018, 03:34 PM   #1
michael bustamante
michael bustamante's Avatar
return fuel line questions
getting ready to plumb the lines.
I have a 5.3 from a 2003 Yukon xl 2wd dbw with the return fuel system.
I know the main line is 3/8 an6 but the return is smaller. 5/16 right?
is there a 5/16 connection at the rail to a 3/8 fuel line or do I need to get 5/16 return line? (PTFE all of course)
also what micron fuel filter should I get. just street, no mods to the engine just yet
1967custom
michael bustamante is offline   Reply With Quote
Old 08-08-2018, 04:35 PM   #2
dec010974
dec010974's Avatar
Re: return fuel line questions
Is there a reason to use PTFE? In any case I used adapters, (2) quick disconnects, at the fuel rails, that convert the fuel lines, the feed line and return line to 6AN. The fuel filter i used, which was 6AN, is 100 microns. Summitracing or the other part houses sells them. good luck on your LSw swap.
dec010974 is offline   Reply With Quote
Old 08-08-2018, 04:38 PM   #3
dec010974
dec010974's Avatar
here are some examples of what i sued for my swap. (1) quick disconnet (2) is a 100 micron fuel filter.
Old 08-08-2018, 04:38 PM   #4
dec010974
dec010974's Avatar
example
Old 08-08-2018, 04:41 PM   #5
dec010974
dec010974's Avatar
example.
Old 08-08-2018, 05:13 PM   #6
mongocanfly
mongocanfly's Avatar
What are your plans for a pump?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-08-2018, 07:19 PM   #7
dec010974
dec010974's Avatar
@mongocanfly I'm going use fuel pump EP381, fuel sending unit FG051M, and either Weld-on Bunges (-6AN) or a Compression fittings to adapt the fuel sending unit to, the -6AN fuel line. I have had great success with this in the past. i also used a jeep(1985-1990) fuel tank. it fits nice, between the frame rails of my 1972 c10.
Old 08-08-2018, 10:31 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
PTFE is nice if your wanting to run flex fuel, and realistically "lasts" longer in terms of resistance to breakdown. You pay the price on the fittings tho.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-08-2018, 11:42 PM   #9
indymachinist
Not to be a buzz kill but most injector manufacturers want no more than a 10 micron filter.
Also, the quick connects with the plastic lock tab are a known fire hazzard. There have been many many stories of them popping off and starting a fuel fire.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 08-09-2018, 06:59 AM   #10
homemade87
I agree about the plastic clip . Get the ones that have the thread . The plastic ones can cause the line to pop out and pump fuel all over .
homemade87 is offline   Reply With Quote
Old 08-09-2018, 07:25 AM   #11
Jstock85
What fittings with the threads are you talking about? Do you have a sample pic. The only ones I knew about were the ones that snapped on.
Jstock85 is offline   Reply With Quote
Old 08-09-2018, 09:19 AM   #12
A1971Blazer
A1971Blazer's Avatar
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 08-09-2018, 09:44 AM   #13
rustycars63
Who makes the fitting and the cost ?
rustycars63 is offline   Reply With Quote
Old 08-09-2018, 09:49 AM   #14
A1971Blazer
Summit Racing...Russell
https://www.summitracing.com/parts/rus-644123
1967 C10 Step side
1968 C10 Step side
Old 08-09-2018, 09:58 AM   #15
rustycars63
Old 08-09-2018, 10:21 AM   #16
A1971Blazer
Originally Posted by rustycars63 View Post
you're welcome....they have them in just about any configuration...
that one is just the first one I saw that had the threaded retainer...
there is another style that also has a positive keeper attached to keep it in place...little pricier...
1967 C10 Step side
1968 C10 Step side
Old 08-09-2018, 03:45 PM   #17
dec010974
dec010974's Avatar
@indymachinist thanks for the info in reference to the plastic retainer used for the quick disconnect fittings. i may need to rethink some things.
Old 08-10-2018, 10:26 AM   #18
Jstock85
going to rethink myself. thanks
Old 08-10-2018, 02:15 PM   #19
michael bustamante
dec0... thanks for all the info. I used the same tank and fender and pump unit you did,
all you guys were a great help. ive ordered all my stuff. thank you.
1967custom
Old 08-11-2018, 09:19 AM   #20
Flubyu
Whats everyone's thoughts on a filler for the Jeep tanks?
'71 C-10 SWB Shop Truck
Currently 350/350, soon to be LS'd.
Flubyu is offline   Reply With Quote
Old 08-11-2018, 12:12 PM   #21
davepl
davepl's Avatar
I've heard it argued that the return line should be as large or larger than the feed line, since it has to carry (at idle, anyway) the same amount of fuel but at lower pressure.
I know on my old '94 LT1 when I put a more powerful pump in, I couldn't keep the pressure down low enough. Turns out the factory return and regulator wasn't sufficient, and I had to upside the regulator.
I'm sure 5/16 would likely be fine. I'm running 3/8 both directions myself.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-11-2018, 10:56 PM   #22
dec010974
dec010974's Avatar
@davepl, I don that before. on my latest LSx Swap, I'm using -6AN braided line for the feed line and return line. @Flubyu I can post more pics and info if its ok by michael Bustamante its his thread, I don't want to take over his thread. I can start my own.
Old 08-11-2018, 11:18 PM   #23
michael bustamante
Dec0 post away buddy. Pics are always good
1967custom
Old 09-14-2018, 08:40 PM   #24
Rob#2
What kind of jeep fuel tank, from a wrangler?
Rob#2 is offline   Reply With Quote
Old 09-17-2018, 01:09 PM   #25
Flubyu
Yes, Wrangler tank (be sure to get a fuel injected version) from a 87-90 Wrangler.
