![]() Join Date: Mar 2013
ECE Trans crossmember trans angle
Afternoon all,
I installed an ECE trans crossmember this weekend. This thing mounts the trans pretty low. I added a few washers between the mount and crossmember to raise the tail a little to add some clearance between the yoke and crossmember but I am still right at 3° down. I know these are for lowered trucks, but is this right? The mount is torqued pretty good. It seems like it is asking for the mount the fail. The image below is what I am working with. It is a little exaggerated due to the camera lens. Last edited by beaterku; 08-08-2018 at 10:28 PM. |
Re: ECE Trans crossmember trans angle
Check your rear end pinion angle. If your transmission shaft angle is 3 degrees down, your rear pinion should be around 3 degrees up. They should be equal but opposite. So the are parallel but offset.
1968 SWB Step Side, Big Block, 4L80E , Running! |
#3 | |
My pinion angle is slightly under 3 without the bed on. So I am more or less equal. I’ll have to check it again when the bed is on and back on the ground. . My concern is how the rubber mount torques when the crossmember is horizontal and the trans is at 3 degree. |
![]() Join Date: Feb 2016
Any chance the front motor mounts are high? If not then I agree with you, it isn't correct and being forced out of a neutral position may or may not cause it or the front mounts to fail prematurely, but it will definitely cause more vibration to be transferred to the truck. I would have a discussion with the vendor about correcting the misalignment.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#5 | |
I know a lot of guys on the board have used this crossmember, curious how theirs looks. |
I didn't know if your truck has had an engine transplant or was stock. I know when I replaced the front motor mounts on my Burban the new ones were about 1/4" thicker and I had to shim the transmission mount to get the pinion angle back in spec. You may have a case of tolerance stacking between motor mounts and a cross member that is slightly out of spec.
#7 | |
![]() Join Date: Aug 2003
Most of 67-72 trucks I’ve had with 400 trans have had metal spacer under trans mount. I think that’s what’s missing.
![]() Join Date: Dec 2013
What engine perches is it sitting on ? By chance it's sitting in the 6 location ?
#10 | |
As far as I can tell, it is on stock SB perches in the correct location. |
Alright, I did some digging and combing through some threads and found another truck with the same crossmember. I stole the first image from 67c10rustbuket. It looks like his trans is angled down about the same as mine. The second picture is mine at a similar camera angle.
Judging by these pictures, it would appear this is how this trans crossmember mounts the trans. |
