Closed Thread
Old 08-08-2018, 07:48 PM   #7101
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by stevenfromtexas View Post
bezel looks great brother!!!!
Thanks . Amazing what 40$and a little elbow grease can do.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is offline
Old 08-09-2018, 07:28 AM   #7102
ncpetersc
ncpetersc's Avatar
The rest
That turned out great!
ncpetersc is offline
Old 08-09-2018, 08:41 AM   #7103
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
The rest
Looks very nice
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is offline
Old 08-09-2018, 03:50 PM   #7104
Orange67
Orange67's Avatar
I turned mine into a barricade to keep people off my new driveway. It's orange, so that works, right?
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline
Old 08-09-2018, 05:31 PM   #7105
Metaldoc
Metaldoc's Avatar
Originally Posted by Canuckvetter View Post
Metaldoc had made them up. Just a cushion between the box and frame. One less squeak or rattle.
I cut them from an old tread mill track and lined my fuel tank straps with it. Make sure you add some ground straps from the frame to the bed. Looking good, when do you get the engine back?
Do it, Do it right, Do it right the first time
Metaldoc is offline
Old 08-09-2018, 07:19 PM   #7106
VWNate1
VWNate1's Avatar
Exclamation Re: What did you do to your truck today? Chapter II
Fresh new Concrete ~ SWEET ! .
I just washed mine again last night and am sad looking at the cracks and how it's settling below the side walk....
-Nate
VWNate1 is offline
Old 08-10-2018, 11:32 AM   #7107
colgad
colgad's Avatar
Originally Posted by rkeller411 View Post
Finished LS swap...
Is that the Holley Mid mount Holley system? It looks so good.
I am about to do a 5.3 swap into my Blazer. I am so tempted to use the Holley system.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 08-10-2018, 01:14 PM   #7108
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Good call on the ground straps! I cancelled the rebuild on that engine last week. Going to go a different route on the CST. 5.3 LS/4L60E. So I'm pulling the 327 out of the CST to put in "The Readheaded Stepchild". It had a recent rebuild and has LT1 double hump heads & and a new duel exhaust system as well as power steering. I expect the CST will be a 4-5yr build as my honey has me on a strict allowance. I have a lot of parts to get started. Time to photograph, remove, clean, paint, bag, tag, shelf. Lol
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline
Old 08-10-2018, 02:19 PM   #7109
Steeveedee
Who Changed This?
Steeveedee's Avatar
Changed the oil this morning and noticed that the power steering reservoir is loose on the fender. Before I just tighten the bolt up, I'd like to see a picture of it properly mounted. There is only one bolt attaching it to the fender, but it has two nuts welded to it. I'm thinking it's not mounted in the right place. GM wouldn't use a bracket like that and not have two bolts in it, methinks.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 08-10-2018, 02:50 PM   #7110
Gregski
Gregski's Avatar
doing some simple wire rerouting as inspired by Lucky Costa of Mobile Tech Lucky. this is where I run the red and purple wires from the starter right into the hole in the firewall right by the starter instead of dragging them across to the bulk head connector, and I do the same for the brown alternator wire and the pink ignition wire run them through another hole in the firewall and into the cab, makes the engine bay look so much cleaner
Gregski is offline
Old 08-10-2018, 03:22 PM   #7111
Orange67
Orange67's Avatar
-Nate
I love it, dont love the circumstances of why it was replaced. But hey, that's what we pay for insurance for.
Justin
Orange67 is offline
Old 08-10-2018, 07:52 PM   #7112
ncpetersc
ncpetersc's Avatar
I don’t think I have a separate reservoir, it’s got a fill cap on the pump. Is your PS aftermarket by chance?
Old 08-10-2018, 08:20 PM   #7113
Ol Blue K20
I believe his truck is a big block. Big blocks had remote resavoirs.
Dale
Old 08-10-2018, 08:48 PM   #7114
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup. After looking at pictures all over the place, it looks like it is in the right place, but if the reservoir mount has two welded-in nuts, it puzzles me as to why there aren't two holes in the fender. That's the way it is shown, but for other years there is a mounting bracket that has the reservoir standing off of either the fender or the radiator core support. I dogged the single bolt down gutentight. That's going to have to be it for now. My FiL did all kinds of hacks to the truck, which I am slowly backing out, like all the power wires he ran under the carpet for some aftermarket geegaws.
~Steven
Simi Valley, CA
Old 08-10-2018, 09:12 PM   #7115
Hank49
Hank49's Avatar
The rest
The bezel turned out nice, what kind of paint did you use on the needles? Just curious
because I want to do mine.
Aaron
Hank49 is offline
Old 08-10-2018, 09:52 PM   #7116
VWNate1
VWNate1's Avatar
Talking " My FiL did all kinds of hacks to the truck "
Don'cha just love DPO & DPM bodges you keep stumbling across ? .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-10-2018, 11:02 PM   #7117
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: " My FiL did all kinds of hacks to the truck "
You mean "Da Previous Owner" and "Da Previous 'Mechanic'"? I don't like finding this kind of c**p. I strive to keep the vehicles I own and maintain done right and safe. It has been my experience that shortcuts lead to disaster at some point. If those wires had somehow shorted out and caused a fire that injured or killed one of my sons (his grandchildren) I'd've been pretty annoyed, to say the least. When I worked as a mechanic, it was especially important to me that the customer understood why I wasn't just going to "patch it together". That way lies great liability in a court of law. That attitude served me well when the BAR sent undercover people in to check on us. We were a state-licensed SMOG, Brake and Lamp station, and I held those licenses. I've turned away people asking me to "just buy off the brake failure ticket so they could go home and fix it", etc.
The only time I made a "blacksmith repair" was on a Sunday, when one of my friend's (drunk) dad drove over a long series of pylons on the freeway and trashed the shifting mechanism and valve body on his Nova. He brought it to me, and I managed to use a punch, hammer and files to get the parts back together so that it would shift from the lever inside the car again. I gave him a list of the parts that needed replacing, but I don't know what he ever did with it. The required parts and an explanation of why they were needed was clearly spelled out on the work order. He may have been my friend, but it protected all of us when the terms were completely spelled out.
~Steven
Simi Valley, CA
Old 08-11-2018, 01:00 AM   #7118
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Today was a milestone, I can start building the truck. Had the frame, cross members, A/C brackets and some other powder coated for the first run. $1150, and well worth it, better than new.
Dropped the axle off for the once over too. They're setting me up with a 1-piece shaft. Guess I better order some suspension huh? Going deep into the pocket this month
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 08-11-2018, 04:13 AM   #7119
VWNate1
VWNate1's Avatar
Post Bodge Repairs
@Steeveedee :
I say 'dang previous owner but it's essentially the same thing.....
easily 1/2 of the repairs I did as a Journeyman mechanic involved some sort of first un - doing some ill considered bodge repair .
You're right the person doing halffast repairs is legally liable but proving who made the mess is difficult .
I mostly worked on older vehicles during my long career so I got to see more bad repairs and patches than do most .
OTOH, I learned a lot about field repairs at the same time.......
-Nate
Geezer
VWNate1 is offline
Old 08-11-2018, 07:49 AM   #7120
72c20customcamper
Krylon fluorescent orange
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-11-2018, 08:00 AM   #7121
Grumpy old man
Grumpy old man's Avatar
Your going to need one of these when your done
Grumpy old man is offline
Old 08-11-2018, 08:42 AM   #7122
Jim Boy
Smile Re: What did you do to your truck today? Chapter II
I had the truck undercoated and a paint protection applied. No waxing till death do us part! A new set of snow tires and I'm ready, cause it's coming.
Jim Boy is offline
Old 08-11-2018, 11:09 AM   #7123
ncpetersc
ncpetersc's Avatar
That's a beautiful Chevelle. What is that exactly some sort of "clean" room for it? Pressurized to keep dirt out or something, or just sealed?
Old 08-11-2018, 01:11 PM   #7124
71CHEVYSHORTBED402
No kidding, that is beautiful. Chevelle in a plastic bubble.
Tony
Old 08-11-2018, 02:58 PM   #7125
Ol Blue K20
It is trying not to catch LStuner disease
Dale
Closed Thread
