Closed Thread
Old 08-11-2018, 03:02 PM   #7126
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by 71CHEVYSHORTBED402 View Post
No kidding, that is beautiful. Chevelle in a plastic bubble.
That Chevelle is gorgeous. If it was mine, there'd be no chance for rust behind the rear tires. That area would have a nice layer of Goodyear PolyGlas GT coating it. I started work out of high school at a Chevy dealer. I loved driving those things!
~Steven
Simi Valley, CA
Steeveedee is offline
Old 08-11-2018, 07:44 PM   #7127
Metaldoc
Metaldoc's Avatar
Never throw away an old dizzy, you never know when you'll need a engine oil primer. Like that time I spun the oil primer on the drill in the air and I bent the shaft. One of those times.
Do it, Do it right, Do it right the first time
Metaldoc is offline
Old 08-11-2018, 09:45 PM   #7128
OregonNed
OregonNed's Avatar
I drove mine to haul myself and my tools to repair the front brakes on a friend's car. It ran and sounded so damn good! I love these trucks!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 08-11-2018, 10:02 PM   #7129
3757chevy
3757chevy's Avatar
I drove to work and parked where I could look at my truck out the front window.I drive 16 miles round trip for lunch 4 days a week. I enjoy the drive ,sometimes I'll even turn on some music. I love my Chevy's.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 08-12-2018, 01:13 AM   #7130
BRL
BRL's Avatar
Originally Posted by 3757chevy View Post
...I enjoy the drive ,sometimes I'll even turn on some music. I love my Chevy's.
Sometimes???
If I ain't blasting myself out of the cab, it's parked somewhere and I ain't in it!
No wonder you love your Chevy's, their !
BRL is offline
Old 08-12-2018, 09:40 AM   #7131
VWNate1
VWNate1's Avatar
Post Pre - Oiling Engines
I always use a bent up coat hanger or welding rod chucked into an old hand drill brace to pre oil engines ~ you needn't spin it fast, just long enough to register pressure on the gauge and have oil weeping out of the rocker lube holes .
The salvaged dizzy idea sounds pretty clever to me .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-12-2018, 07:49 PM   #7132
rcazwillis
Washed the frame and undercarriage.
Zane's 71 Build
rcazwillis is offline
Old 08-12-2018, 08:45 PM   #7133
3757chevy
3757chevy's Avatar
Originally Posted by BRL View Post
Sometimes???
Thanks. I love the sound of the exhaust so much, it's like music to my ears.
MIKE
Old 08-12-2018, 11:31 PM   #7134
Tkrysl
Getting started on some new parts. My first project truck. Sat for 20+ years. I can tell there are a few "new" parts that aren't OEM, but I think these plugs and wires are original 72. Whatcha think?
Tkrysl is offline
Old 08-13-2018, 01:06 AM   #7135
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Those plugs don't appear to have many miles and they're clean and tan so mayhap that's a good engine to bring back to life .
No worries about the broken insulator, time to get upset when the bottom threaded part remains in the cylinder head..... .
-Nate
Geezer
VWNate1 is offline
Old 08-13-2018, 06:17 AM   #7136
FRCvette
Installed ece front sway bar and drove it.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline
Old 08-13-2018, 03:07 PM   #7137
beaterku
beaterku's Avatar
Flared a short section of stainless brake line. Failed to flare of section of brake line. I was trying to shorten a pair of stainless lines on my rear end to work with my disc brakes. The line and/or tool did not like the small 3/16" line... 1/4" line was perfect.
beaterku is offline
Old 08-13-2018, 04:59 PM   #7138
Metaldoc
Metaldoc's Avatar
Re: Pre - Oiling Engines
I tried tig wire but I didn't like it. The old dizzy shaft works great.
Metaldoc is offline
Old 08-13-2018, 08:48 PM   #7139
BRL
BRL's Avatar
I did the same as you, but went a slightly different route.
Ground the teeth off of the gear and reduced top dia. for a 3/8" drill.
Still keeps the shaft from sliding off of the pump slot.
Haven't used it in years as the engine is still doing just fine!
BRL is offline
Old 08-13-2018, 09:42 PM   #7140
ZEKE68
ZEKE68's Avatar
Got the pinion back in the rear with new bearings. No sleeve crush yet. Got the new carrier bearings installed and the ring gear switched over to the Eaton carrier, ready to go in. Started installing the brackets for the No Limit upper mount sway bar, and found I had a u bolt with striped threads. got to order a set. Also found my left rear brake line was almost mashed shut on the back of the axle. That must have been like that for years. But I am getting closer each day!
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline
Old 08-13-2018, 09:59 PM   #7141
ZEKE68
ZEKE68's Avatar
ZEKE68 is offline
Old 08-14-2018, 12:34 AM   #7142
JMD
JMD's Avatar
Put a few miles on the new top end, and fried the alternator.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline
Old 08-14-2018, 03:07 AM   #7143
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Kind of counter productive but I sold mine today.
oldiron is offline
Old 08-18-2018, 06:14 PM   #7144
jabborabbo
jabborabbo's Avatar
Replaced the heater hoses...while I was taking the wire clamp off the 5/8 inch hose, it popped out of my pliers, sailed into the driver’s side engine bay, rattled around and disappeared (that’s my conclusion after spending 30 minutes looking for it - which included taking the driver side front wheel off)
Used hose clamps to secure the hoses on the heater core, then spent 20 minutes trying to get the metal thingie that holds the hoses together, failed, and just used a cable tie.
I hope that clamp didn’t end up somewhere that will cause me problems later....
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline
Old 08-18-2018, 08:05 PM   #7145
Andyking1203
This was yesterday... but I welded up some of the spot weld holes, and cut some of the firewall out.. had help with cleaning!!
Andyking1203 is offline
Old 08-18-2018, 09:48 PM   #7146
ZEKE68
ZEKE68's Avatar
Finished my rear end rebuild, and installed brake adjusting holes in my rear drum backing plates.
ZEKE68 is offline
Old 08-18-2018, 10:20 PM   #7147
Steeveedee
Who Changed This?
Steeveedee's Avatar
If it wasn't under the right front tire, keep looking. That's the kind of thing you hear a couple of weeks later going click...click...click, and have to repair a tire. Just ask me how I know this.
I spent so many hours at about that age scrubbing parts that you wouldn't believe it. We couldn't afford chemicals, so it was "just wear out the screwdriver or brush"!
~Steven
Simi Valley, CA
Old 08-18-2018, 10:40 PM   #7148
Quikshft
Quikshft's Avatar
Today I finished the install of an auxiliary fuel tank. It's a 31 gallon unit which gets me about 50 gallons total as I have elected to keep the tank behind the seat. Looking forward to fewer (but more expensive) stops at the gas station which can be a real inconvenience with a travel trailer in tow.
Quikshft is offline
Old 08-18-2018, 11:06 PM   #7149
jabborabbo
jabborabbo's Avatar
It wasn’t under the tire - I looked about 3 times.
Old 08-18-2018, 11:28 PM   #7150
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
What is that tank out of?.It looks great!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is offline
Closed Thread
