Old 08-12-2018, 05:56 PM   #1
karlbenz
dual fans?
we put dual fans on my sons 63. the circuit breaker keeps kicking when it gets warmed up. can I put a bigger circuit breaker on or should I wire them separate with different relays and breakers?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 08-12-2018, 07:03 PM   #2
Clyde65
Clyde65's Avatar
Re: dual fans?
Why two fans? How big are the fans and which fans did you get?
Many electric fans pull huge amounts of amps when starting. I suggest using relays to draw your power from the battery directly as well.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-12-2018, 07:07 PM   #3
karlbenz
Re: dual fans?
2-12” fans. Came with a 30amp circuit breaker and one relay
relay is 40amp
1965 Chevy C60
Old 08-12-2018, 08:59 PM   #4
Clyde65
Clyde65's Avatar
Re: dual fans?
Got A/C?
Wire the one to come on when engine starts and then the other @160 if that’s what thermostat is.
If you have AC, then use a tri-nary switch to kick the one on with AC and at temp.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-13-2018, 06:32 PM   #5
karlbenz
Re: dual fans?
Originally Posted by Clyde65 View Post
Got A/C?
No ac
1965 Chevy C60
Old 08-13-2018, 07:41 PM   #6
Clyde65
Clyde65's Avatar
Re: dual fans?
No need for dual fans, just use a 16” spal fan, puller that pulls at least 2200 cfm
Clyde65
Rebuild of Clyde
support our troops!
Old 08-13-2018, 08:07 PM   #7
karlbenz
Re: dual fans?
No offense but I was looking to figure this here out. Not looking to buy another fan. I think I got it now though
1965 Chevy C60
Old 08-13-2018, 11:32 PM   #8
Captainfab
60-66 Nut
Re: dual fans?
I would wire them with each having it's own breaker and relay but controlled with the same sensor
Old 08-14-2018, 07:25 AM   #9
karlbenz
Re: dual fans?
That’s what I did. Thanks
1965 Chevy C60
Old 08-14-2018, 07:28 PM   #10
Clyde65
Clyde65's Avatar
Re: dual fans?
None taken, glad you got it ironed out!!
Clyde65
Rebuild of Clyde
support our troops!
