05-11-2004, 08:25 AM | #1 |
shorty header question
How difficult is it to change your oil with the shorty headers? I know the long tubes get in the way and you have to reach around them or go in from the passenger side to get to the oil filter. And on a lowered truck it is not too easy.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
05-11-2004, 06:28 PM | #2 |
It won't make a lot of difference, the header is in the way on the long tubes but the front Y pipe or whatever you have there on the shorties will be in the way too. Oil filters with a hex key on the bottom are the easiest to remove in tight places. Also, never use those band type wrenches, get a proper 3 jaw wrench, they compress when you turn them and positivly grab the filter case. Minimizes the chance of tearing the case and having to remove the filter with special tools (or a chisel)
05-11-2004, 06:39 PM | #3 |
driving is in my blood
I have headman longs on my 78 and ramhorn's [same size as shorties] on my 79 and neither are any sort of a problem to change the filter on. Heck on the 79 you can get to the filter from any angle you want. No reason to worry.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-11-2004, 06:41 PM | #4 |
Garage Queen Material
i dont have any problems with my shorties
05-11-2004, 07:38 PM | #5 |
no problems here
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
05-11-2004, 08:44 PM | #6 |
none here, infact mines much easier now with the Sanderson Shortys
75 GMC C-15 short/step factory 454, lowered |
