Radiator 70 c 20
Anyone know the exact radiator measurements on a 1970 c20 with 350 small block i tried searching came up empty ,thanks in advance.
Posted via Mobile Device |
Who Changed This?
![]() Join Date: Jan 2013
Re: Radiator 70 c 20
I have a 400, so I'm not much help. Somebody else should chime in, sooner or later.
Who Changed This?
Yes. If you have the truck, do you need to know what needs to be measured, for you to get the right dimensions?
#5 | |
That would give me pretty much ball park dimensions right? Thanks Posted via Mobile Device |
Will the size of an aftermarket aluminum / plastic be fine, or do you need the size of the original copper / brass?
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
Who Changed This?
My radiator is 34" from outside to outside of the tanks, and 19" high. You could have one that is narrower if you have a 350 without AC. Do you have the radiator core support available to measure? The hole should be about 29" for the radiator like I have since it stops at the edges of the core.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Two radiators I found with a quick search...
Hope this helps. Bill
Who Changed This?
That 28-3/8" core size corresponds to the hole, closely enough. I'll have to measure my core's thickness- it is a four-row brass job.
#11 | |
#13 | |
#14 | |
