Old 07-31-2018, 09:29 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Parked in a Field for Over 4 Years.
It's been parked out at my friend's property and not started for over 4 years. We're going to go out there and try and get it started.
I'm taking about 10' of fuel line, a fresh can of gas, a battery, an extra carb, and maybe 10' of wire. Also some tools of course.
Am I forgetting anything?
That's it with the wood stacked on its utility bed.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-31-2018, 10:18 PM   #2
60short
Revitalizing a 6T C10
60short's Avatar
Re: Parked in a Field for Over 4 Years.
starting fluid, oil filter, brake fluid, points / condenser (or matchbook)
60short is offline   Reply With Quote
Old 07-31-2018, 10:30 PM   #3
LostMy65
LostMy65's Avatar
Oh yeah, brake fluid.
It has an HEI.
Old 07-31-2018, 10:40 PM   #4
nsb29
nsb29's Avatar
Your AAA card
nsb29 is offline   Reply With Quote
Old 07-31-2018, 10:50 PM   #5
andyh1956
Wasp Spray!
andyh1956 is offline   Reply With Quote
Old 07-31-2018, 11:22 PM   #6
DPowers
One foot in front of the other
DPowers's Avatar
Add PB Blaster and a weedeater to your list.
DPowers is offline   Reply With Quote
Old 07-31-2018, 11:40 PM   #7
LostMy65
LostMy65's Avatar
Great suggestions.
My buddy said if we could at least get it to the main road, we could use his triple A card to to my shop. :-)
Very likely we'll need a weedeater and wasp spray.
Old 08-01-2018, 09:32 AM   #8
66K20
66K20's Avatar
If that truck was left in a Kansas field for 4 years the cab would be filled with rodents. One of the first things we do when pulling a vehicle from a field (or barn) is to leave heavy bowl of antifreeze on the floorboard a week before. Then when you go back and sit in it a rodent won't brush against the back of your leg
Brett | 1966 K20 - 292/SM420/T221
66K20 is offline   Reply With Quote
Old 08-01-2018, 10:14 AM   #9
jweb
jweb's Avatar
A portable compressor to fill the tires and a chain to pull it out. They usually sink in the ground around here.
You may also want some water or coolant if you plan to actually drive it.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 08-01-2018, 02:07 PM   #10
pholmes350
Check the oil for water first.
pholmes350 is offline   Reply With Quote
Old 08-01-2018, 02:27 PM   #11
dtkarst
Small hose clamps for temporary fuel hoses too. I’ve forgotten those little bastards so many times and had them pop off or leak lol but some pb is a good call. And a good pair of vise grips just in case
dtkarst is offline   Reply With Quote
Old 08-01-2018, 02:39 PM   #12
michael bustamante
michael bustamante's Avatar
marvel mystery oil, a long neck funnel and spark plug socket set to lube up cylinders. couple gallons of water for radiator and a broom handle in case the hood hinges are wore out, and a .22 to peg the critters coming out of the truck
1967custom
michael bustamante is offline   Reply With Quote
Old 08-01-2018, 02:45 PM   #13
mongocanfly
mongocanfly's Avatar
Throw a bug bomb in the cab a run....but
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-01-2018, 10:23 PM   #14
LostMy65
LostMy65's Avatar
Thanks for all the suggestions.
Us old men after spending most the morning on the lake decided we'll just rent a trailer and haul it back to my house.
Old 08-01-2018, 10:53 PM   #15
DPowers
DPowers's Avatar
Old and WISE men...
Old 08-02-2018, 08:03 PM   #16
Old65C10
4 Years, that's nothing. I pulled my truck out from behind a barn where it had sat for 22 years.
I have changed out the fluids, put on new hoses and belt, new brakes etc. But is is up and running and will soon be my daily driver. Oh, and new tires.
I was lucky, mine was here in Yakima Wa. Super dry all year, so the motor spun by hand with ease.
They can be resurrected.
Old65C10 is offline   Reply With Quote
Old 08-03-2018, 01:13 AM   #17
LostMy65
LostMy65's Avatar
It's just been killing me having it sit out there.
I had done so much to it, and i don't want that to be wasted.
Mechanically it has all the 73-87 upgrades.
14-Bolt Full Floater. Complete Front Crossmember with New Power Steering and Power Disc Brakes.
New windshield rubber. New rear window rubber. New cab mounts. Nice 90's Service Box. And only a few miles on a GM Goodwrench 350. I was restoring it to be a work truck for my construction company. But now having a desk job and my 65 back, I have no need for it, but I can't leave it out there either.
Old 08-03-2018, 07:45 AM   #18
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I like the trailer it home idea. It's like bringing all your tools to the site , in reverse...lol
Old 08-18-2018, 03:10 PM   #19
LostMy65
LostMy65's Avatar
Do you guys think my 65 c10 with a 283, a TH350, and 3:73 rear gears can tow this 66 c20 service truck?
Old 08-18-2018, 03:15 PM   #20
Clyde65
Clyde65's Avatar
With trailer brakes?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-18-2018, 03:44 PM   #21
jdl71
jdl71's Avatar
If you have a receiver hitch and trailer brakes, yes. Or do you mean with a tow bar or chain?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 08-18-2018, 04:03 PM   #22
LostMy65
LostMy65's Avatar
I'm thinking with a tow dolly.
And taking the back roads.
Old 08-18-2018, 04:41 PM   #23
Killer Bee
Killer Bee's Avatar
what I've gotten away with and what I'd recommend to others are two different animals..
wishin' you good luck and in to see results and pictures..
Old 08-18-2018, 07:19 PM   #24
jdl71
jdl71's Avatar
You'll be fine.
Psalm 23
64 C10
66 K20
Old 08-18-2018, 07:20 PM   #25
jdl71
jdl71's Avatar
Ha! Isn't that the truth.
Psalm 23
64 C10
66 K20
