Old 08-19-2018, 01:07 PM   #6
68 P.O.S.
Re: carb problem?
Yes, Edelbrocks do not like a lot of fuel pressure; no more than 6. Edelbrock recommends either their Perfomer RPM fuel pump, or an inline regulater set to 5.5, or else they flood. They also need a heat insulator gasket. They get hot and percolate the fuel, which causes hard starting issues. You definitely need to check your fuel sock, filter, and fuel lines to be sure there's no restrictions. Also, what is your timing like?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
