Old 08-20-2018, 11:50 PM   #1
AASmedic
AASmedic's Avatar
Been through everything, What am I missing?
OK Peeps. I need some input. I began having an issue back in February while driving at 65 mph on the interstate. The motor began to sputter and jerk and I thought it was vapor locking (as it was rather warm that week) or the fuel pump was going bad. I got off the freeway and drove surface street speeds (45 or less) and the issue seemed to resolve itself.
I finally got some time over the next few months so I replaced the fuel pump and all of the filters. Nothing changed. I then moved on to the carb and rebuilt it. I wrapped the fuel line with heat resistant tape and put a sleeve on it. Nothing changed.
I read another forum that addressed the same symptoms I am experiencing and it suggested that the pick up in the distributor was bad. I replaced the distributor, cap, rotor and coil, re-timed everything and nothing changed.
Another recommendation was to change out the thermostat. I put in a 160 degree thermostat and still, you guessed it, nothing changed.
What am I missing? Any help or suggestion would be appreciated.
Thanks,
Kevin
My Paypal address is: http://paypal.me/KFerguson66
72 K20 Cheyenne Super
My "re-build" thread
http://67-72chevytrucks.com/vboard/s...?t=710221&goto
Thread for my Reproduction Jack Bags
http://67-72chevytrucks.com/vboard/s...d.php?t=715455
AASmedic is offline   Reply With Quote
Old 08-21-2018, 12:53 AM   #2
kwmech
Re: Been through everything, What am I missing?
Did you check the rubber fuel lines themselves?
Old 08-21-2018, 12:55 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The only thing I can think of is did you change the little filter at the fuel inlet (if it's a q-jet)?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 08-21-2018, 04:15 AM   #4
AASmedic
AASmedic's Avatar
Yep, checked all the fuel lines, no leaks
Old 08-21-2018, 04:16 AM   #5
AASmedic
AASmedic's Avatar
Replaced the tiny rascal at the inlet too.
Old 08-21-2018, 05:08 AM   #6
SIXTY9
Have you checked the screen on the fuel send unit in the tank?
SIXTY9 is offline   Reply With Quote
Old 08-21-2018, 05:36 AM   #7
AASmedic
AASmedic's Avatar
No hadn't thought about that one but if that was clogged, wouldn't it act like it was starving for fuel throughout the RPM range and not just at the top end?
Old 08-21-2018, 05:43 AM   #8
SIXTY9
Guess on how bad it is. Just a thought.
Old 08-21-2018, 06:24 AM   #9
Nh4clo4
Nh4clo4's Avatar
Sixty9 probably is right. I had a similar issue with one many years ago. Only did it at highway speeds.
Nh4clo4 is offline   Reply With Quote
Old 08-21-2018, 06:59 AM   #10
CUSTOM/10
CUSTOM/10's Avatar
Same here, was fine at low speed but would sputter and even die on the hi-way. Check it out !
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 08-21-2018, 07:04 AM   #11
67 chevelle
67 chevelle's Avatar
1 vent line or cap , when it does it again , pull over and take the gas cap off and resume ride , if that fixes it you will know , 2 your fuel line may be bent or the rubber swollen also
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-21-2018, 08:28 AM   #12
Is there a hard line all the way to the pump? If there is rubber between tank and pump it could be collapsing at higher RPMs.
Old 08-21-2018, 08:46 AM   #13
KJSR
KJSR's Avatar
Will it do it at the same RPM in a different gear? Does it take a bit to start happening or is it as soon as you get to 65ish? Try driving in a lower gear at the same RPM range and see what happens
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 08-21-2018, 09:02 AM   #14
Mike C
Mike C's Avatar
I mention this a lot, but there is an old hot rodders adage that says "90% of carb problems are ignition".
Make sure everything is in tip top shape. Plug wires are routed away from anything they may arc to and are in good shape. You don't have a broken plug, cracked cap or damaged rotor. That all connections are clean and tight.
Once that is 100% squared away and it still has issues start looking at the fuel again.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-21-2018, 10:20 AM   #15
AASmedic
AASmedic's Avatar
Thanks for all the pointers guys. The problem seems to be in the 2500-3k rpm range or about 65mph. It is generally after it has been driven a few miles. I hadn't thought about the vent issue either. I will check pick up screen and re check incoming fuel line. Cap, rotor, plugs and wires all new.
Old 08-21-2018, 11:15 AM   #16
michael bustamante
michael bustamante's Avatar
also don't forget to check the rubber fuel lines for softness, my line would actually pinch itself almost shut last year with how hot it was
1967custom
michael bustamante is offline   Reply With Quote
Old 08-21-2018, 11:24 AM   #17
davepl
davepl's Avatar
I must say it does indeed sound like a fuel starvation (delivery) issue from the symptioms.
I'd say fill the float bowls with fuel so it'll run a few seconds, then disconnect the fuel line at the carb and put it into a clear bottle so you can see what's happening. Fire the motor so it'll run for a few seconds using the residual fuel in the carb.
You -should- get a strong and steady flow of gasoline into the glass jug. If it's anything but an impressive flow of fuel, I'd imagine you've confirmed it.
Goes without saying, but gasoline is evil and dangerous. Be paranoid and safe around it.
(BTW, if its q-jet, don't forget the filter and screen in the inlet of the carb itself)
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-21-2018, 11:38 AM   #18
KJSR
KJSR's Avatar
Those RPM's are not that high. Does it start at 2500 and continues to max rpm (over 3k)?
You may want to run the truck in the driveway at night and see if you have spark jumping from anywhere at higher RPM's. That is after its warm and is missing.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
Old 08-21-2018, 11:46 AM   #19
KJSR
KJSR's Avatar
Oh yeah, I didn't see.....HEI or points? You mentioned a "pick up" in the distributor so I'm guessing electronic. I would also consider the ignition module if its an HEI. The coil can cause this as well especially since its doing it after its warm.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
Old 08-21-2018, 01:36 PM   #20
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I just cured a similar problem with my truck. I too changed the fuel pump and everything else is new. My truck kinda died at fast idle then sputtered while driving and even backfired sometime. A friend told me to try running Premium Gas in the truck. I have been gassing my truck at the same place for 10 years always running regular unleaded but was at my wits end so filled it up on Saturday with premium and it seems to have cured the problem the last 2 days driving around city and highway.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-21-2018, 01:37 PM   #21
68 P.O.S.
Clogged fuel sock on sending unit in the tank? What carb do you have? What is your timing set at?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-21-2018, 01:41 PM   #22
custom10nut
custom10nut's Avatar
Did you check the filter on the pickup line in the tank?
custom10nut is offline   Reply With Quote
Old 08-21-2018, 02:26 PM   #23
ManNamedJed
Sounds like you've already addressed these, but I'll add them here in case someone with similar problems reads these threads.
I had similar issues in a jeep. Finally tracked it down to the foil 'High Energy' sticker on the ignition module in the distributor had come loose and would occasionally flutter around and cause the engine to sputter and die.
Had another similar issue with another jeep. Turned out the rotor in the distributor was cracked and was rotating 15 degrees or so on the shaft. There was enough tension still there that it would return to normal at idle, but move around at anything above that.
ManNamedJed is offline   Reply With Quote
Old 08-21-2018, 04:32 PM   #24
rsgt
rsgt's Avatar
Check the crimps and connections that power the HEI. Where do you power it from?
rsgt is offline   Reply With Quote
Old 08-21-2018, 08:20 PM   #25
whtgmc68
whtgmc68's Avatar
I had nearly the same problem with my truck when it still had the 350 that was in it when I bought it. I replaced the carb, fuel pump and filters. Turned out there was so much gunk in the fuel tank that I just replaced it since it was about the same price to have the orignal boiled out and properly cleaned.
Never had another problem and when the engine finally got a proper flow of fuel, it ran so well that I almost hated to replace it with the 383.
whtgmc68 is offline   Reply With Quote
