Old 08-21-2018, 08:20 PM   #1
whtgmc68
whtgmc68's Avatar
Re: Been through everything, What am I missing?
I had nearly the same problem with my truck when it still had the 350 that was in it when I bought it. I replaced the carb, fuel pump and filters. Turned out there was so much gunk in the fuel tank that I just replaced it since it was about the same price to have the orignal boiled out and properly cleaned.
Never had another problem and when the engine finally got a proper flow of fuel, it ran so well that I almost hated to replace it with the 383.
whtgmc68 is offline   Reply With Quote
Old 08-22-2018, 09:52 AM   #2
ZEKE68
ZEKE68's Avatar
Had a very similar problem on a 55 chevy I had once. Turned out the ballast resister had gone bad and was sending 12 volts to the distributor. These trucks have a resister wire instead of a ballast I believe, so it's likely not the same problem. But as stated ignition problems can seem like fuel problems.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 08-22-2018, 03:42 PM   #3
AASmedic
AASmedic's Avatar
Not an issue here. I have an HEI ignition.
My Paypal address is: http://paypal.me/KFerguson66
72 K20 Cheyenne Super
My "re-build" thread
http://67-72chevytrucks.com/vboard/s...?t=710221&goto
Thread for my Reproduction Jack Bags
http://67-72chevytrucks.com/vboard/s...d.php?t=715455
AASmedic is offline   Reply With Quote
