Old 08-22-2018, 12:44 PM   #1
ZEKE68
ZEKE68's Avatar
Power brake petal drop question
I have installed a stock power brake setup on my 68, and I don't have the engine running yet. I have bleed the brakes but the pedal will still go down slowly if I keep pressure on it. Is this normal with power brakes and no vacuum?
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 08-22-2018, 01:38 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Power brake petal drop question
What all changed? Did you just add a booster and master? Do you have the shoes all adjusted to the drums?
~Steven
Simi Valley, CA
Old 08-22-2018, 02:07 PM   #3
ZEKE68
ZEKE68's Avatar
Petal is very firm and doesn't go far down on the initial push, but with continued pressure it moves slowly down to the floor.
Old 08-22-2018, 03:51 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Is it the old master cylinder? That's a symptom of a bypassing piston, which indicates that it should be replaced or rebuilt.
~Steven
Simi Valley, CA
Old 08-22-2018, 07:38 PM   #5
ZEKE68
ZEKE68's Avatar
Brand new. Its a 1 1/8" bore for power brakes. Took off my 1" bore manual brake master to install it.
Old 08-22-2018, 07:40 PM   #6
Boog
laying low
Boog's Avatar
The fluid is going somewhere. It's either bypassing inside the master or there is a leak somewhere.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-23-2018, 12:01 PM   #7
tdangle
tdangle's Avatar
I agree not right. Should hold up longer than your leg will. Either a leak in the system or a bad master cylinder
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
