Rear Swaybar--worth it?
Looking for some info from those of you that have installed a rear swaybar on these trucks (specifically the 1/2 ton coil spring models) I'm doing the front sway bar for sure, but don't how much the rear swaybar helps. Thanks
1968 C10 - 383, non-stop project 1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies |
Do it!! You will think you are driving a vette. Put one on my 71 Cheyenne short bed and it make a great deal of difference.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
I will be installing a rear sway bar from a Camaro on my 72. I also have a front sway bar to bolt on soon. I have heard it makes the handling of these trucks amazing
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Got mine here(front and rear kit-$289.00)
www.classicperform.com
#5 | |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Remember when adding a rear sway bar you need to use a larger than stock front bar.
Otherwise your truck will have a push. This would be worse than the loose condition you had with no rear bar. You will be amazed at how it handles with 2 correctly matched bars ![]() |
