Old 08-24-2018, 08:08 PM   #1
Pontiac1976
Pontiac1976's Avatar
Re: Cleaning your windshield
Whatever you use do not use in direct sun light, three steps- wet, wipe it off clean with a thick microfiber. Use a missed a low strained microfiber re-do the window. Then a dry low strained microfiber. Then then do two steps for Rain-X it helps keep the window cleaner longer + makes the easier to see in rain if your caught in it.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-24-2018, 08:43 PM   #2
sweetk30
sweetk30's Avatar
x2 on no major hot glass .
x2 on rain-x products . and thats my opinion from a professional driver everyday .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
