Old 08-19-2018, 11:43 AM   #1
CW4B
CW4B's Avatar
70 C20 750CFM Quadrajet Vacuum Hose Connections
Can you share some pictures that show the vacuum hose connections on your C20 quadrajet carburetor? Thanks in advance.
70 Chevy C20 3/4T 8-400 Longhorn
CW4B is offline   Reply With Quote
Old 08-19-2018, 04:05 PM   #2
geezer#99
geezer#99's Avatar
Re: 70 C20 750CFM Quadrajet Vacuum Hose Connections
Search with ‘google images’.
https://www.google.com/search?tbm=is...24.mqR5qv2dJOQ
Old 08-19-2018, 06:12 PM   #3
CW4B
CW4B's Avatar
Hmm, if only that easy.
Old 08-19-2018, 07:27 PM   #4
geezer#99
geezer#99's Avatar
How so?
You got a pic or a link to the carb you got?
East to tell you what goes where that way.
Old 08-20-2018, 03:19 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Your truck is quite similar to mine. What is the number on your carburetor? If it has been changed for something else, it may not have vacuum ports like original.
My truck has the vacuum advance port on the front of the carburetor, opposite where the fuel supply line enters.
PCV port is on the front.
Choke pull-off (if you have an automatic choke) port is right next to the pull-off, with a hose about 1.5" long.
The brake booster has a connection on the manifold, not on the back of the carb.
There is another live vacuum line that attaches near the choke stove in the carburetor base plate; it goes inside the cab and is hooked to the (non-original) vacuum gauge.
Transmission modulator vacuum also feeds from the manifold, like most vehicles.
That's all I have on mine.
~Steven
Simi Valley, CA
Old 08-25-2018, 11:41 AM   #6
CW4B
CW4B's Avatar
Helpful steeveedee, thanks.
