Old 08-27-2018, 09:07 PM   #1
bautino95
what size to plug disconnected brake lines at the rearend
Hey, I'm gonna pull out my rear-end assembly and in doing so I need to disconnect my brake lines from the block where they split on the rear-end. What it size bolt or pipe thread do I need to plug it so I don't have it leaking the whole it I have the rear-end out. thanks
bautino95 is offline   Reply With Quote
Old 08-27-2018, 09:13 PM   #2
bautino95
Re: what size to plug disconnected brake lines at the rearend
Pic
Old 08-27-2018, 09:25 PM   #3
jmking9
jmking9's Avatar
What I would do is disconnect the two hard lines from the brass tee and leave the tee connected to the flex line. The tee should un bolt from the axle. Plug the two open ports of the tee with inverted flare plugs that can be bought at Napa for a couple bucks a piece. It's hard to tell from the picture if the hard lines on your axle are 3/16" or 1/4". If they are the smaller 3/16", you will need two 3/8"-24 inverted flare plugs. If they are the larger 1/4" line, you will need 7/16"-24 inverted flare plugs. Hope this helps
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 08-27-2018, 10:20 PM   #4
Wrenchbender Ret
You can take some inverted flare nuts & solder or braze the end closed or cut a short piece of tube off an old brake line with flare nut on it. Squese the tube closed on the end & bend it over & squese it again. Put those in the outlets on the hose.
Wrenchbender Ret is offline   Reply With Quote
Old 08-27-2018, 10:46 PM   #5
bautino95
Thanks, inverted flare plug is what I want.
Old 08-27-2018, 11:21 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup. And every decent parts store has them.
~Steven
Simi Valley, CA
Old 08-28-2018, 08:55 AM   #7
S_Gibson
S_Gibson's Avatar
If the fluid is as dark and nasty as what I just found in my truck let it drain into a bucket so you can add new fluid. Fluid is cheap and you will have to bleed your brakes anyway.
If it is the same size as I just found on my '70 it is a 3/8 flare for the tubes to the cylinders.
Stupidity was meant to be painful!
S_Gibson is offline   Reply With Quote
Old 08-28-2018, 01:26 PM   #8
87Skier
87Skier's Avatar
I went to a hardware store and picked up a few of all their sizes of rubber plugs. I had my axle out for a few weeks changing the gears and bushings and had no leaks during that time.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
